Oil level sensor - How to replace molded plug
  • cory58
    • 1021
    Bumping this thread again because it's the perfect example of why I love this forum and why the FB group can never replace it. The plug on my oil level sender disintegrated earlier this year and I found this thread through a Google search. Many thanks to fitswell and shawshankNG for posting the critical info that enabled me to buy and wire the new plug. I plan to by another plug EFI Express "just in case." THANK YOU!
    Cory
    1992 325i Cabrio
    1988 320i Touring
    2000 M5
    1977 530i
    2015 328i - Euro Delivery/Performance Center Delivery
    BMWCCA
    E30CCA
    • blalor
      • 217
      Sometimes the internet really is amazing. Thanks for your help, everyone!
      EFI Motorsport (as they're known, now) call it "Bosch Style (Amp Junior Power Timer) 3 pin male connector kit", and moments after ordering 2 of them I found some alternative sources.
      I believe the male part of the housing is TE/AMP part number 1-962581-1. The closest I can find on te.com is 1-962581-2 (https://www.te.com/usa-en/product-1-962581-2.html), but Mouser still has the -1 version right now. https://www.mouser.com/ProductDetail...o%252BPQ%3D%3D
      Corsa Technic has the housing for < $4: https://www.corsa-technic.com/item.p...ategory_id=146
      A thread on bf.com https://www.bimmerforums.com/forum/s...6#post30322546 suggests there's a BMW part number 12521732564 which looks right on Turner: https://www.turnermotorsport.com/p-4...uine-bmw-part/
      Hopefully that helps some folks in the future.
      • rogue38
        • Jul 2011
        • 54
        This is where i got mine. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
        Trying to sort out the wiring now.
        Got it installed, but the area the wires go in is a little to long, getting the boot back over was a little difficult.
        2006 330i 6 Spd Man, ZSP, CA, SG, Black ette, Burl, Sat Prep.
        ED 29 May 2006
        1990 325i, 5spd, Calypso Red, Tan
        • jjjjj
          • Jun 2019
          • 88
          nine years later the EFI link still works, same price. who knew this and the costco corndog would be the only things immune to inflation. thanks everyone for helping another car get back on the road!
          • zaq123
            • Jul 2016
            • 1530
            I'm glad i bought the whole new sensor when I did (3 years ago). Looks like its NLA. Time to rebuilt my old sensor (thanks all for the connector course) and keep it as a spare.
            • Kai_NK
              • Nov 2018
              • 2
              Originally posted by Just Scott
              Found this on EFI express for $12.50 plus shipping.
              If you are careful, you won't need to use the crimps. Carefully break the old plug apart with a pair of pliers or something and reuse the crimps after you bend the lock tabs up a bit.
              Winner, winner, chicken dinner
              Thank you!!!
              • Hlu1
                • Dec 2018
                • 6
                Thank you for all the valuable info. I bought the plug from efi and fixed my sensor over the weekend. The light finally went away!
                • JerEazy
                  • Jun 2025
                  • 35
                  Gotta resurrect again for this post! Helped me figure out what’s what.
                  but brings an interesting question: why not just waterproof butt connectors like we would do for something on a boat and wrap in some electrical tape or heat shrink?
                  wiring diagram I found was red/wht to grn/yel - yel to brn - brn to blue. Never worry about busted connector again?
                  • Vincenze
                    • Apr 2019
                    • 1030
                    This connector https://www.digikey.com/en/products/...581-2/10468547
                    uses rubber seals (the wire diameter must be checked to identify the correct seal):
                    https://www.digikey.com/en/products/...8904-1/2054422
                    • JerEazy
                      • Jun 2025
                      • 35
                      not sure what you mean here. The wires are the same size coming from sending unit to connector.
