Icv quick fix
  • Dirty325ix
    • Sep 2012
    • 689
    Icv quick fix
    So I remember reading somerhing about a quick solution for a broken icv in which you put a dime with a hole drilled in it into the icv.
    what is the size of hole I drill in the dime?
  • Gregs///M
    • Mar 2012
    • 2459
    Never tried it but I remember the guy said it was a small hole. Anything around 2mm I believe.
    You should instead trying cleaning the ICV first unless the electrical coils are out of spec.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Dirty325ix
      • Sep 2012
      • 689
      You clean it by spraying it with wd40 or should I take it apart and clean it?
      It still clicks if I shake it
        • 37833
        Clean it out with carb cleaner or brake cleaner. The clicking when you shake is it a GOOD thing.
        Grover Beach, California
        BimmerHeads.com
        • IRON-E
          • 16548
          +1 best method to use, not wd40.
          @IRON-E30 aka Edwin:D
            What makes you think the ICV is broken? If just that the idle is off, there are a number of possible causes for that. If the ICV doesn't vibrate when the ignition is switched on, the first thing I'd check would be the TPS. Otherwise, for idle problems, start at the top of what follows and work to the bottom without skipping any steps.
            Idle or hard starting problems are most commonly caused by intake leaks and/or
            a sticky or defective Idle Control Valve (ICV). The only reliable method of
            locating intake leaks is to have a smoke test run on the intake and crank case
            and to test the brake booster with a gage and vacuum pump. The complete list
            of possible causes of an intake leak is:
            Intake boot
            Throttle body gasket
            ICV hoses & connections
            Brake booster, hoses, and connections
            Crank case breather hose
            Evaporative control hoses, valve, and expansion tank
            Fuel pressure regulator & hose
            Injector seals
            Valve cover gaskets & bungs
            Oil filler cap
            Dip stick o-rings
            Oil return tube o-rings
            While leaks in some of those can be found by inspection or by spraying carb
            cleaner on suspect areas, not finding leaks that way doesn't eliminate the
            possibility. Only a smoke test will really work.
            Once the possibility of intake leaks is eliminated, the ICV needs to be
            removed and cleaned with carb cleaner until the vane inside moves freely. When
            the ignition is switched on you should be able to feel vibration from the
            ICV. If no vibration the ICV is bad, there's a problem with its wiring or
            connector, there's a problem with the TPS, or the DME (or Idle Control Module
            (ICM) on an ETA car) is faulty.
            For the DME (or ICM) to control idle, the idle switch in the TPS must work
            correctly. The switch should close when the throttle stop is 0.030-0.060" off
            the idle stop screw. Hearing a click doesn't mean the TPS is working. Check
            with a meter or test light.
            The fuel system should be tested via the suite of tests in the Bentley manual
            as invalid rail pressure can be a contributor to idle and starting problems. A
            simple injector check is to pull the injectors, jumper the fuel relay to run
            the pump, and see if the injectors are leaking. You can also point the
            injectors into a towel, remove the coil wire, and crank the engine to see if
            all of the injectors appear to be spraying in a similar fashion. The best
            approach to possible injector problems is to have the injectors cleaned and
            flow tested. Since raw fuel can or will be released in these tests, have a
            fire extinguisher handy.
            While a bad check valve in the high pressure pump can result in longer than
            normal cranking, if the fuel system is working as it is supposed to the rail
            will reach normal pressure in a few turns of the engine. A weak pump, clogged
            filter or leaking FPR in conjunction with a failed check valve can result in
            longer cranking and/or idle poroblems.
            The O2 sensor can be a contributor to idle problems. The O2 sensor is a
            scheduled maintenance item with a useful life of no more than 100k. If the
            sensor has that mileage or more (or is of unknown age), replace it.
            The AFM can be a contributor. If the vane doesn't move freely or the
            resistance track is worn the DME may be receiving invalid data from the
            AFM. And if someone has fiddled with the bypass air adjustment the DME may be
            unable to stabilize idle. The bypass air adjustment should only be adjusted
            per the procedure in the Bentley and with an exhaust gas analyzer. And even
            then everything else associated with engine management has to first be
            operating properly. If the AFM becomes a suspect, replacement with a good used
            unit is the best approach.
            Improperly adjusted or malfunctioning valves will affect idle and starting. As
            can compression issues from ring or cylinder wear. A valve adjustment is
            called for every 15k. A useful diagnostic is to run compression (dry and wet)
            and leak down tests on the engine. Aged ignition wires, plugs, distributor
            cap, or rotor can cause problems. Insulation does break down with time and
            heat. And since the youngest E30 is going on 20 years old, if the ignition
            system is original or the plugs are old replacement is indicated.
            Although not usually a problem, a bad DME temp sensor is a possibility. That
            generally won't cause an unstable idle, but can cause hard cold or hard hot
            starts and/or a rough idle. As can problems with the timing reference
            sensors. Although not commonly encountered, a bad harmonic balancer on an
            M20B25 or M30 engine will cause problems.
            When all other possibilities have been eliminated and idle or starting
            problems persist, replacement of the DME, or if applicable the ICM, is
            indicated.
            In many cases the cause of problems will be a combination of factors. So it is
            important to test and repair all of the possible causes.
            • e30slidewayz
              • 813
              ^nice little troubleshooting guide there jlevie. I'm trying to track down an idling issue after I installed a performance head, injectors, and full exhaust. I've replaced the throttle body that leaked on a smoke test, cleaned the ICV, and checked hoses. I'm thinking the new O2 sensor I installed that has longer leads is the culprit, just have to splice in the old one that worked fine to check that. Could an exhaust leak directly behind the O2 sensor cause idle issues (the joint between the long tube headers and midpipe)?
                The length of the wire on the O2 sensor won't be a problem. An exhaust leak close to the O2 sensor could be a problem.
