I get a random 1222 code. The whole story...
'90 325i, ~180k miles on the car, ~130k on the m20.
A few weeks ago my car started to idle rough when cold and didn't run to well until driven for a minute or so. It go worse when it was near zero degrees. So, I knew it was the temp sensor.
On the way home from work (25 miles) three days ago, it started bucking a bit then missing fairly bad. To the point where my top speed was about 50mph. Then it came right out of it. The check engine light came on, then went back off. Stomp test = 1222.
An hour later I drove it for about 10 minutes with no issues. Next morning drove it 25 miles to work, no issues. Drove home after work, same random bucking, missfire. It would run bad for 3 or 4 second sometimes, other times it would run bad for a few minutes. Again, code 1222.
I replaced the temp sensor that night. Took it for a 10 minute drive, no issues. It ran fine when cold, idle well, ran good when warmed up. Yesterday morning, drove to work, no issues. Last night on the way home, same issues came back.
So now, I know it's not the sensor itself. I know the possible causes of 1222. Here are some of the variables... I filled the car up with gas last Friday, haven't put any more in it since. I'm at 1/4 tank. Issue first appeared at 3/4 tank. Plug wires are less than a year old, plugs look good. I checked all the electrical connectors at the injectors. Double checked connetor for temp sensor. FPR, fuel filter, ICV, are all about a year old. 17# injectors were cleaned and "rebuilt" and installed with MarkD chip about 9 months ago.
To do list... Test CPS, check injector harness connection, and if need be check fuel pressure. The problem with the fuel pressure test is that the issue is random. I've had fueling issues in my race car, and this does have similiar characteristics. I'm just wondering if I have a fuel pump issue, as far as I know it still has the original setup.
I know the things I need to check. Does anyone know of anything I'm not thinking of here? Any other ideas? Sorry for the long post, just wanted to get all the details in here.
