Anyone know what size AN fitting oilcooler lines are?
  • DTMbimmer07
    • 1485
    My stock ones leaking so I'm just going to replace it with an after market one since i will be boosting the car. So does anyone know what the AN size is that screws into the side of the block?
  • Northern
    I like cupcakes & sh!tboxes
    • 5283
    I dont think it would be an AN style fitting in the block, it should be some sort of metric size fitting
    Originally posted by priapism
    Originally posted by shameson
    • SkiFree
      • Jun 2011
      • 2766
      You're going to need to make adapters. The block (and cooler) is not threaded for AN.
      ADAMS Autosport
      • DTMbimmer07
        • 1485
        well its not technically the block.
        http://realoem.com/bmw/showparts.do?...29&hg=11&fg=30
        Its number three where the oil filter screws onto.
        • DTMbimmer07
          • 1485
          Do you know who sells adapters?
          • TG Goose
            • Jul 2011
            • 234
            they are metric 22. you need 22mm to x size where x is the an fitting of your choice. I have a pair of -6 and -8's, I can ship from Vancouver, BC, but probably cheaper to find locally at a hose/line company.
            ______________________________________
            1984 LSB 318i - Sold
            1986 325i - Motor Swapped Track Car Project
            1995 318ti - Sold
            1999 540iA - Daily Driver
            • SkiFree
              • Jun 2011
              • 2766
              http://www.madabout-kitcars.com/foru...ead.php?t=2148
              ADAMS Autosport
              • DTMbimmer07
                • 1485
                Thanks! Found them on Summit but there like 20 bucks a piece any other sites you guys know of that might have them for cheaper?
                *Never mind found them on Summit for like 9 bucks each.*
                • SkiFree
                  • Jun 2011
                  • 2766
                  uhm.... howabout a used M20 factory oil cooler? Not something I'd cheap out on.
                  ADAMS Autosport
                  • DTMbimmer07
                    • 1485
                    Rather get a after market oil cooler so i can move it to up behind the kidney grills, so i can mount my intercooler down by where the stock oil cooler sits.
                      To accommodate an AN fitting oil cooler on my Spec E30 I had a hose shop make up hoses that had the OE 22mm fittings for the oil filter adapter on one end and AN fittings on the other.
                      • DTMbimmer07
                        • 1485
                        That's the oil cooler I'm looking into getting.
                        • DTMbimmer07
                          • 1485
                          Hey Levie
                          Do you think these would work?
                          Free Shipping - Fragola Performance Systems AN to Metric Adapter Fittings with qualifying orders of $109. Shop Fittings and Adapters at Summit Racing.
                            I can't tell. There is no picture so I can't see how those seal. The OE parts use an o-ring at the ring flare and 22mm gland nuts.
                            • DTMbimmer07
                              • 1485
                              Couldn't I get a crush washer type think for it?
                              This is the Russel version of it but i looked up the Fragola one and its the same design
                              Free Shipping - Russell AN to Metric Adapter Fittings with qualifying orders of $109. Shop Fittings and Adapters at Summit Racing.
