Why doesn't r3v have a delete thread feature.
  • burlmays9
    • 227
    Car blew up and it was fantastically fabulous and spectacular everything was fun and nobody cried. The shits I give are whatevz the internet is at my disposal. Still too incompetent to delete my own thread, I apologize eternally for rustling any jimmies in the wrong way. I'll give personal apologies if I did indeed rustle you in the wrong direction.
  • burlmays9
    • 227
    So pins 7 and 13 are the same on either plug. Pin 7 is ignition switch and 13 is fuel pump relay but not getting fuel or spark. Kind of lost
    • crazyman
      • Dec 2010
      • 738
      I know you did a engine swap but when I was having that issue on my ETA it wound up being the crank position sensor. Worth a shot maybe.
      85 swartz/metallic 325E
      84 alpine 325E
      85 zinnoberot 318i/R.I.P
      84 Bronzit 318i/sold
      purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
      • burlmays9
        • 227
        No power to dme/ecu
        Yeah I tried switching them around to no avail.
        Everything is together just not getting power to the DME/ECU.
        • crazyman
          • Dec 2010
          • 738
          Well that stinks fixed all for me doing that. If you go to my profile I have a link there for a pdf format of a Bentley manual. Hope that helps.
          84 alpine 325E
          • TobyB
            • 5296
            ok, so we can all play this game, I guess.
            • burlmays9
              • 227
              Originally posted by TobyB
              search "C101" and all will be revealed...
              t
              Damn man thanks! Not like I already considered that or anything and the ECU doesn't get power from C101. Thanks for reading as I just mentioned it has no power at the DME/ECU
              • burlmays9
                • 227
                Problem solved!
                • cabin
                  • Dec 2006
                  • 552
                  Originally posted by burlmays9
                  Problem solved!
                  So you took the time to post this, but you couldn't mention what your issue was?
                  Not that I want to know, but it could help someone in the future with a similar issue. I hate searching threads only to find the last post being "fixed!!!" or "problem solved!!!" with no additional insight...
                  /rant :hitler:
                  -Justin
                  Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                  • dashboardmonkey
                    FUCK YOUR WAFFLES
                    • Jun 2008
                    • 6158
                    ^ yeah, cause everyone around here is sooooo helpful.
                    -Andy
                    • burlmays9
                      • 227
                      /rant :hitler:
                      If you don't like my problem thread then feel free to find another! They're all over this site.
                      • LJ851
                        • 7919
                        You can delete your own thread.
                        Lorin
                        The M30 is God's engine.
                        • Vivek
                          attention whore/retard/bitch
                          • 6167
                          Dude what. Why not take 2 extra minutes to explain exactly what the issue was and how you fixed it. Then it's there forever for someone to find and it can help them.
                          1992 Mauritiusblau Vert
                          2011 Alpinweiss 335is coupe
                          2002 540i/6 Black/Black
                          2003 GSX-R 750 (RIP)
                          • cabin
                            • Dec 2006
                            • 552
                            Lol, my jimmies are certainly rustled. Its not that I dont like your thread, Im just tired of seeing this over and over again. It really helps no one. Im glad you took the opportunity to respond the way you did, when you could have spent less time sharing what your actual problem was. Thanks for your contribution to our community.
                            -Justin
