Sorry, I meant to title that "Cam Pulley"
I was tightening up my cam pulley during my timing belt job, and the cam pulley moved about 3 teeth from TDC. The belt was not on at the time so I don't think the crank was affected. Can I simply rotate the cam pulley back around to TDC without the belt on and be good to go? Or do I need to put on the belt and rotate both the crank and cam pulley until they are lined up again?
