1988 325e No Power
  • robert1700
    • 1151
    1988 325e No Power
    Just did a bunch of work to my 1988 325e and now its idling very bad and has no power when I press the gas. I also just did a hot soak. Stomp test shows 1221 but the DME is reading a brand new O2. Also the cae has the same issues whether it is hot or cold.
    Things Ive checked:
    All wires have spark and are going to the correct position in the distributor plug. I also ran wires from my own car. Same problem.
    Fuel pressure is dead perfect.
    AFM and ICV test perfect, I swapped from two other cars, same issue.
    The muffler has been on its way out. I thinking clog cat or muffler. Thoughts?
  • e34_spangler
    • Dec 2012
    • 311
    Its possible not sure but I'd say it have tp be pretty dang clogged to be doing tjis but jm probably wrong
    Sent from my SCH-I535 using Tapatalk 2
    • robert1700
      • 1151
      Fog test the vacuum no leaks
      • robert1700
        • 1151
        Tomorrow I am going to pull the o2 sensor off, see where Im at. Its new but read that could be part of the problem
          Fog test? That sort of sounds like you tried to do a DIY smoke test. Which is okay if the test was done properly. That would mean plugging the exhaust, replacing the AFM with am adapter for smoke introduction, and pressurizing the system to 2-4psi of smoke. That pressure must be held for at least 5 minutes.
          The symptoms described are consistent with intake leaks, a fuel delivery problem, a bad AFM, or a plugged exhaust. Diagnose in that order.
