Engine wont start
  • Superbuick3
    • Mar 2013
    • 34
    Engine wont start
    The other day i was just stopped at a red light and it turned green so i started to go, and right when i started to pick up speed my engine shut off. It wasn't overheating, temperature was normal. There wasn't any noises or anything it just shut off, so i pulled over and tried to start it again. At first it was cranking pretty good and almost starting but it just wouldn't start. I called my friend to come out and help me jump it (luckily when it died i was only 5 minutes from my house) and it did not do anything.
  • Todd Black 88
    • Oct 2007
    • 3449
    Pull the oil cap and try to start it. Take a Look and see if the cam turns when cranking. If it doesn't your timing belt snapped.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • dnguyen1963
      • Nov 2011
      • 2651
      Classic symptoms for a snapped belt.
      • EatsHondas
        • Sep 2012
        • 404
        My timing belt snapped at idle about 2 weeks ago. There were no horrible noises at all, it sounded like I had just turned it off normally. When I tried to start it again, I could hear the starter buzz. The valvetrain wasn't moving and didn't make the customary 'woosh-woosh-woosh' sound when the motor is spinning but not running.
        Do what Todd Black 88 suggested for a diagnosis. If the cam doesn't move, you'll have to pull the head or swap the motor. All 6 of my pistons have slight dings on the exhaust side and my #5 intake rocker sheared in half. Remember, mine went at idle. If you were moving, you definitely broke something.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
