M20 horrible fuel economy
  • Slicktop_serg
    • Nov 2011
    • 198
    So i recently got my car running and i am now daily driving it and i noticed my fuel economy is horrible. I changed my O2 sensor and coolant temperature sensor... and it sort of got a lil better but still bad. I haven't changed the fuel filter or spark plugs. but i check the spark plugs and they were black which means mad carbon... sooo any suggestions on what i can do before replacing more things? Please help thank you..
    91' Alpine II 318is Slick top - Totaled
    89' Lachssilber 325is - :p
  • Gregs///M
    • Mar 2012
    • 2459
    Check for vacuum leaks.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • efficient
      • Feb 2012
      • 3312
      -thermostat to make sure its running at its proper operating temperature.
      -fuel filter
      -plugs/wires
      -cap n rotor
      • bmwstudent
        • Sep 2011
        • 1364
        check air filter too
          • 37832
          Sounds like you need to do a FULL tune up. Spark plugs, cap, rotor, valve adjustment, fuel filter, valve cover breather hose, air filter, etc. You should also check the TPS for proper adjustment.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • E30_fiend
            • Apr 2006
            • 7348
            On board for all of that. You should probably also change your valve cover gasket during the valve adjustment.
            Other than that, the only other thing I can think of is checking your intake boot for cracks. A big unmetered vacuum leak will cause your O2 sensor to switch to its rich limits to protect the motor from damage.
            Taylor
              • 37832
              Good point Taylor. Check the condition of the intake boot and idle control valve hose.
              Grover Beach, CA
              www.BimmerHeads.com
              • Slicktop_serg
                • Nov 2011
                • 198
                Thanks guys will check and keep you posted if i need anymore advice/help
                • K1CKBAC
                  • 306
                  What is your current mpg?
                  My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
                  • Slicktop_serg
                    • Nov 2011
                    • 198
                    obc went from 14mpg to about 23.5 now but im only getting about 150-160 miles on a tank. and im driving conservative. I feel like its just drinking the shit out of it
                    • Slicktop_serg
                      • Nov 2011
                      • 198
                      That was after changing the coolant temp sensor
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        160 mi per tank? What kind of car do you have? My 325IC get about 24 mpg (@380 mi per tank) overall even with winter tires.
                        • CabbE30
                          • Aug 2009
                          • 2358
                          That's way too thirsty. I agree what everyone else has said about the tune-up. You can also check your afm:
                            You don't say if the car has an M20B27 or M20B25 engine, but for the most part the actions will be the same:
                            1) Replace the distributor, ignition wires, and install a fresh set of NGK ZGR5A plugs.
                            2) Replace the O2 sensor
                            3) Adjust the valves
                            4) Check engine operating temperature with a contact or IR thermometer (should 80C)
                            5) Verify that the ECT signal as measured at the DME is correct
                            6) Check rail fuel pressure
                            7) Have a smoke test run and fix any leaks
                            8) If the cover of the AFM shows it to have been removed, replace the AFM.
                            9) Have the injectors cleaned, rebuilt, and flow tested
                            10) Have a back pressure check run to see if the catalytic converter is clogged, replace if indicated.
                            If the problem persists the next actions would be to:
                            1) Get dry and wet compression numbers and hot leak down numbers
                            2) Put the car on a dyno and get AFR curves for part and full throttle operation
                            What to do then would depend on what those results are.
                            • harold30
                              • Jul 2011
                              • 180
                              I have the same problem. I have replace almost all of the above list aside from distributor, rotor and valve adjustments that I'll do next. But before hand, is there any signs that the distributor and rotor needs to be replaced?
                              Thanks...
