Whine after changing TBelt, Water pump
  • EtaSax
    • Mar 2012
    • 89
    So today brought a change of the Timing belt, TBelt tensioner, thermostat, and waterpump. The belts got a little wet with antifreeze. After all was said and done, there remains a relatively loud whine that changes with RPM. The whine seems to come from the TBelt area. The Tensioner that was removed spun freely. The new Tensioner from Bav did not spin freely. It was installed and now the whine is occurring. Could I have a defecting Tensioner or something else. I have a video with the noise up shortly.
    If you are a wind player and you aren't a woodwind, you are just being a brasshole...
  • psigti
    • Sep 2012
    • 290
    could be a defective tensioner. a
    every time I had a whine from a timing belt it was because i had it too tight.
    Sent from my SCH-I535 using Tapatalk 2
    • vert_this
      • Feb 2012
      • 395
      to tight is what I'm thinking too..other possibility could be a timing cover misaligned down low rubbing the belt.
      but if your new belt was covered in antifreeze anyway you may not want to use it cause it will cause it to have a shorter than expected life.
      • EtaSax
        • Mar 2012
        • 89
        The tightness was set by the tensioner spring only. It sprung into position and that's where it was tightened. If it is too tight, does that mean that it must be loosened or will it just whine with no ill effects?
        Is the tensioner pulley supposed to spin freely or should it have resistance?
        The new belt didn't get wet. Come to think of it, it was kind of stupid even mentioning that. With the TBelt being cogged anyway it shouldn't matter.
        What does that leave? A misaligned cover? All the covers seemed to be aligned. I guess I'll check again.
        Sent from my Galaxy Nexus using Tapatalk 2
          • 34827
          I always get this with a new belt. Should go away after a few days.
          • vert_this
            • Feb 2012
            • 395
            a new tensioner should have resistance and not spin on its own w/o applied force.
            • Bimmerista
              • Nov 2005
              • 5425
              I experienced the same thing when I had a new timing belt/water pump installed 3 weeks ago. After a few days, the sound went away.
              • e30construction
                • Jan 2013
                • 591
                planning to do this ina week or so..hope i dont get a bunch of whining..how loud is it?
                93 325i 120k
                mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
                future mods: chip, m3 cams, headers, turbo
                • EtaSax
                  • Mar 2012
                  • 89
                  It's moderately loud. You can't hear it in the car or while you are driving but it's loud enough to hear with the hood closed at rest. I'll drive it for a few days and see what happens. If it persists after a week I'll look into more. I'm just a little nervous but for good reason: a failure here could potentially ruin an otherwise fine motor. On the other hand, I guess it does open the door for a 24v swap...
                    The noise could be from the tensioner and there is a way to find out. With the engine cold remove the v-belts, and run the engine for no more than a minute. If it makes noise then, it has to be the tensioner.
                      • 34827
                      I'm sure it will go away once the belt breaks in.
                      • EtaSax
                        • Mar 2012
                        • 89
                        Just an update, the noise APPEARS to be decreasing slightly. Hoping it will cease all together by the end of the week. If it's whining not due to a belt breaking in, what's the prognosis as far as how long the belt will last if it is too tight/rubbing? I'm trying to gauge how long I should wait while the belt breaks in before I get really suspicious that the noise is more than a belt breaking in.
                        • mohamedsayed
                          • Jun 2024
                          • 1
                          Hello hello!
                          This is a long time ago now. Do you remember what the conclusion was for this?
                          Thanks!
