87 528E Extended crank and no start.
  • DrtyE30
    • 656
    My e28 last week started to randomly have extended cranks, now if I let it sit for more than 5 mins it won't turn over right away. I can hold the key and it just cranks and cranks, doesn't how many times I do it. But once I get it running its fine, a few times it stalled right away but runs smooth. This is my first b27 and I don't know a bunch about it. Any ideas?
    91 318is M50 swap
    89 325ic
    12 WRX Daily
    86 325e Sold
    88 325is (Parted out)
    06 330XI (Sold)
    91 318is-M20 turbo Sold :(
    91 318ic (Sold)
    87 528e (Sold)
    93 318is E36 (Parted out)
    92 325ic (Parted out)
    94 325i E36 (Sold)
    88 325ix (Sold)
    Click my Signature to see the build!!^
  • DrtyE30
    • 656
    Changed the DME relay,fuse is good, pulled the fuel line and wasn't getting fuel. But if I push start it it will stay running even if I rev it high or drive it. Would the crank sensors do that?
    91 318is M50 swap
    89 325ic
    12 WRX Daily
    86 325e Sold
    06 330XI (Sold)
    91 318ic (Sold)
    87 528e (Sold)
    94 325i E36 (Sold)
    88 325ix (Sold)
    • Cletonius
      • 2809
      If your crank sensors are bad your car shouldn't run at all. It's worth testing them but I don't think that's the issue. You might want to replace all the fuses. My car became a bunch more reliable once I swapped out the 20+ year old fuses.
      Edit: what about the fuel pump relay? Might be sticking?
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • DrtyE30
        • 656
        That's what I thought as well, but I just got some fuses and will put them in when I get out of work tonight. I tried swapping it with a questionable relay I had but once I get to my shop i'll try it again.
        91 318is M50 swap
        89 325ic
        12 WRX Daily
        86 325e Sold
        06 330XI (Sold)
        91 318ic (Sold)
        87 528e (Sold)
        94 325i E36 (Sold)
        88 325ix (Sold)
        • harold30
          • Jul 2011
          • 180
          If you pulled the fuel line and not getting fuel then it must be either faulty fuel pump or clogged fuel filter...
          If this happened to you when your engine is hot then the fuel pressure could be a problem, it will flood your intake manifold with fuel and thus hard starting occurred. Just based on my experience but I'm sure some experts here can answer you promptly. hth
          • DrtyE30
            • 656
            Well I kept messing with it and changed all the relays and fuses and got it to turn over. But now it won't rev past 4k rpm. It starts up every time but the whole not going past 4k thing I need to figure out, not having a power band sucks!
            91 318is M50 swap
            89 325ic
            12 WRX Daily
            86 325e Sold
            06 330XI (Sold)
            91 318ic (Sold)
            87 528e (Sold)
            94 325i E36 (Sold)
            88 325ix (Sold)
            • dnguyen1963
              • Nov 2011
              • 2649
              Your TPS might be feeding the wrong info to the DME.
              • DrtyE30
                • 656
                That makes sense, I have a spare TPS that i'll throw in this weekend.
                91 318is M50 swap
                89 325ic
                12 WRX Daily
                86 325e Sold
                06 330XI (Sold)
                91 318ic (Sold)
                87 528e (Sold)
                94 325i E36 (Sold)
                88 325ix (Sold)
                • DrtyE30
                  • 656
                  Try changing the tps, dme, fuel pressure regulator, vacuum hoses, and I still can't get it to rev past 4k. If its dead cold it will go to 5k but struggles to get there, when it's hot it sounds like fuel cut off when I reach 4k. Also since I did all this work when its cold I have extended cranks, but not at any other point.
                  91 318is M50 swap
                  89 325ic
                  12 WRX Daily
                  86 325e Sold
                  06 330XI (Sold)
                  91 318ic (Sold)
                  87 528e (Sold)
                  94 325i E36 (Sold)
                  88 325ix (Sold)
