M20 Oilpump shaft needle roller bearing.
  • bangn
    • Sep 2011
    • 760
    I am trying to track down the part number for a needle roller bearing.
    Its located in the block, the gear that runs off the intermediate shaft that the oilpump drive shaft pushes into runs off two needle roller bearings.
    one needle roller I have found the part number for pushes into the aluminum cap, the other one is located in the block, this is the one I cant find a part number for, I cant find it on the fische.
    is it the same bearing that goes into the aluminium cap? on the other end of the gear?
    hope this makes sense.
    Boris - 89 E30 325i
    84- E30 323i
  • digger
    • Nov 2005
    • 6144
    http://www.realoem.com/bmw/showparts...17&hg=11&fg=10
    no 23
    • bangn
      • Sep 2011
      • 760
      thats the one in the aluminium cap I have, there is one in the block too. Not sure if its the same bearing tho. Im wondering if BMW removed it from the system like they did the Intermediate shaft shells as they were "too hard" for your average jo to replace.
      Boris - 89 E30 325i
      84- E30 323i
