m20 valve tick
  • mod_junkie
    • Jul 2012
    • 285
    m20 valve tick
    So my m20 ticks loud to me and is driving me nuts. a couple of r3v members told me it was normal but I dont know hahaha. Its unacceptable so how loud should the tick be if its normal?
    Originally posted by Rocla
    And yes, you must remove complete assembly from the car, unless you are a gynegologist
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Do a valve adjustment and run 20w-50 that should help
    88 325is Five Speed
    Lachssilber
    • Mr. Tasty
      • Jul 2011
      • 3421
      m20's are sewing machines bro
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • mccor023
        • Jul 2011
        • 683
        I feel your pain! After a few attempts myself at a valve adjustment I still wasn't happy with the tick. I ran the heavy oil that's been said and even took it to shop and paid a "professional" who is also an E30 guy.
        I'm still can't believe the ticking I hear is normal and now I'm thinking of a rebuild or 24v swap.
        I love that people ask stupid questions so I dont have.
        • mod_junkie
          • Jul 2012
          • 285
          yea I guess I'm gonna have to a valve adjustment and some heavier weighted oil
          • JinormusJ
            • 6887
            I had a HORRIBLE valve tick from unadjusted valves; I could hear it at low RPMs with the music blasting. Once I adjusted it, it was much quieter, but with silence inside, you can still faintly hear "valves" but you can't hear them very well until 3-4k RPMs
            Valve tick is just an m20s business; adding heavier oil, despite popular belief, will do little to help. When your valves are adjusted well and everything is going smoothly, what you're really hearing is Injector whine, and also something that comes with m20 territory. Valve lash is only heard under load after 3k RPM, and even then, it shouldn't be terribly loud (faintly distinguishable over moderate volume music)
            Sorry, but m20s are just loud. What your hearing is most likely how it's always been
              Valve tick isn't "just the way an M20 is". Incorrectly adjusted valve and/or too thin an oil will increase the noise level. But if the head is in good condition, the valves correctly adjusted, and the correct oil is used you should only hear a slight tick on a cold engine that almost completely disappears once the engine is at normal temperature. Worn valve guides will cause the valves to be noisy, regardless of adjustment or oil.
              • mod_junkie
                • Jul 2012
                • 285
                so I've done a valve adjustment and oil change with heaver weighted oil and I see no change. It's just as loud as it was before... I'm at a loss at what to do now. I know everyone says its normal but I don't think it should be that loud at all.
                • nickmcc92
                  • Dec 2012
                  • 442
                  When a motor is 20+ year old wear happens. That's why some say its normal but a car doesn't come out of the factory ticking.
                  Adjust the valves to .008" not .010" (spec) and see how you like it
                  • ak-
                    • 12422
                    The head on your car is old.
                    Mine is old.
                    Everyone's is old, except for the select few who've done a complete rebuild.
                    Get a Mystery-e performance head/rebuild or #dealwithit :p
                    edit: what nickmcc said.
                    1991 325iS turbo
                      • 37832
                      Time to rebuild your head.
                      We can do stock too. Not going to throw a sales pitch at you but PM me if interested.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        Pretty sure that you need to re-build the head, but just make sure that the noise is not coming from the injectors. They make ticking noise too.
                        • mod_junkie
                          • Jul 2012
                          • 285
                          but how loud of a ticking noise would they make?
                          • mod_junkie
                            • Jul 2012
                            • 285
                            Here's what it sounds like after the valve adjustment and oil change..
                              When that video was taken was the engine at normal operating temperature? If so, the valves are way too loud.
