85 eta rough misfire black soot from exhaust
  • 2.5-12
    • Jan 2010
    • 1814
    I did a ton of maintenance items on this car last summer, it ran alright before it, but now it is just being an a-hole.
    parts serviced
    distro cap
    distro rotor
    plug wires
    plugs
    flywheel, clutch and pp
    intake boot
    full 325i header back exhaust system
    (DME is and was chipped)
    changed intake manifold
    changed throttle body
    changed TPS
    intake manifold gasket
    ICV plug gasket
    hose clamps on everything
    injector o-rings
    I have since tried:
    swapping ICVs
    swapping green idle boxes
    swapping DMEs
    swapping AFM and barometric sensors
    swapping coils
    swapping plug wires
    swapping cap and rotor
    symptoms
    car will start (after a fair bit of cranking.) will idle rough and low (now idles semi-smooth at about 900rpm), when the gas is stabbed briefly, it revs up normally like an eta should nice and strong, but if the pedal is pressed only slightly the car runs even rougher and eventually will stall. when this happens, the exhaust has black soot that comes out (snow bank behind car is stained black).
    the car drives, when on the gas or off the gas its ok, but partial throttle it jerks violently.
    things I have read about that I should double check
    cold start injector (car runs the same with or without idle at 900rpm)
    test fuel pressure (tested within spec)
    test compression (less inclined since car ran fine before)
    ideas? I have a lot of experience with ETAs, but this one has been a bigger PITA than most.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
  • 2.5-12
    • Jan 2010
    • 1814
    here's an old video of it.
      One thing not mentioned in your list of things to check is to have a shop run a smoke test to look for intake leaks.
      • 2.5-12
        • Jan 2010
        • 1814
        I will add it to the list, but the car ran perfectly before these maintenance items, and I didn't remove the intake in the process
        • dnguyen1963
          • Nov 2011
          • 2649
          Whenever you work on a 20+ yrs engine, you will undoubtedly jar something loose. Have a smoke test done to find the vacuum leaks. Vacuum leaks can come from many other places beside the intake boot.
          • 2.5-12
            • Jan 2010
            • 1814
            while this is true, I doubt it would cause the highly rich fuel mixture.
            • dnguyen1963
              • Nov 2011
              • 2649
              I listened to your video. I still think you have vacuum leaks. It is worthwhile to look at the injectors to make sure that they are not leaky. Have you removed the spark plugs to see if they are fouled? For troubleshooting E30, it is best to eliminate vacuum leaks before doing anything else.
              • 2.5-12
                • Jan 2010
                • 1814
                ok, lets move on to what I should check besides vacuum leak
                it isn't a vacuum leak, I know them well in M20s and this has a different set of behavior.
                I will check injectors for impedance and operation with a stethescope
                beyond that -- remember it is running filthy pig rich.. sticking cold start injector, improperly flowing fuel injector
                I will remove the plugs to see if they are fouled, and to check the gap. probably remove the disto cap again to check and make sure nothing is screwed up there.
                anything else to check?
                  Intake leaks can lean out the mixture to the point that the engine is misfiring, which will result in there being partially burned and unburned fuel in the exhaust. Which will look like the engine has too rich a mixture.
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    I'll smoke test the intake to appease you guys.
                    anything else in the mean time potentially problematic?
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      Not to appease me, but I would be happy if you can get your E30 going again. You might also want to check the ignition coil. A weak coil might not give out a strong spark resulting in rich running condition.
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        I have swapped coils, but I should try another just in case
                        my winter car is a perfect running eta as well, so I will probably take parts and swap on that to see just because they are known working.
                        I have a ghetto intake smoker made from a DJ fog machine and some very high temp rated hose, I will smoke test it for giggles. (kinda hope you guys are right on an intake leak coming form nowhere, would be cheap and easy to remmedy)
                        one thing I just thought of... TPS?
                        • dnguyen1963
                          • Nov 2011
                          • 2649
                          I have a similar setup. The output of the fog machine goes into a large enclosed tub. I then use an aquarium pump to pump the smoke into the engine. The small pump is perfect to keep the pressure at about 4 psi. Don't forget to plug the exhaust and intake.
                          • 2.5-12
                            • Jan 2010
                            • 1814
                            so tested fuel pressure at 27psi, but when I removed the vacuum line to the FPR I got a perfect 37psi..
                            in the video, the fuel pressure spikes when I hit the throttle -- is that normal?
                            patched the fuel leak and it runs a lot better, attached another video, found a crack in the intake manifold, but its not letting air in.
                            ...havent smoke tested it just yet...
                            • 2.5-12
                              • Jan 2010
                              • 1814
                              So, I think that's it for this weekend. I am going to swap the TPS and the 3-4 sensors on the thermostat housing to see if that makes any difference.
                              (Forgot my smoke machine downtown, derp)
                              Fuel pressure and fpr behavior are apparently normal, so that's good.
