Another newb 2.7i stroker harness question
  • SleepyE30
    • Mar 2013
    • 4
    i am new to BMWs.. sorry for the ultra noob question and has probably been asked many times . i have a 87 eta 5speed and im interested in doin the 2.7i stroker turbo. i have been reading the how to 2.7i stroker thread and was wanting to know if i need to get a manual transmission engine harness from the 2.5i and does the harness need to be modified in any way to work with the eta? i am already looking for parts for this build on this forum and locally. but i am stuck on this question at the moment. any info is appreciated.
    • 37829
    There is no difference in manual and auto engine harnesses.
    If you get a harness from an 87 325i/is it will be plug and play. If you get an 88+ harness you will need to wire the tach.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • SleepyE30
      • Mar 2013
      • 4
      So an 87' 325i/s engine harness on 87'eta block will plug and play with the 173 ecu, 89'-91 885 head and all the parts to make a 2.7i stroker? if i go with the 88+ harness.. i think i read the 88+ 325i gauge cluster will work without having to wire it up?
      • Gary Horneck
        • May 2011
        • 435
        Yes it will plug right in. And the i cluster will work fine.
        2011 335i/1995 Mercedes C220 (rallyx)
        • SleepyE30
          • Mar 2013
          • 4
          :D Ok i will start looking for parts for my 2.7i stroker turbo build. hoping to finish this in a months time.
