ok so heres what i got: 1987 BMW 325is
hx35
blowoff valve
charge tubing
2.5'x8x14 intercooler
turbo header (equal legnth tubes)
all the guages you could want to monitir vitals
WAR chip
so i put the car all together and kaboom. byebye head gasket. i took it apart replaced the gasket and when i was timing my engine i noticed a hissing sound when a compresion stroke would happen so i figure i toasted some rings. the head is sound so i know its not leaky valves. i had the oil pan off and heard the noise from the bottom end. so now the car is setting and has no need to be drivin because i am going to school at uti in az and the car is in idaho and while i am in my foirst program here im going to rebuild my ford diesel truck. so my plan is to build the spare m20 that i have and by the time im done with school ill have my truck and m20 ready to go. the rpoblem im having is sourceingthe parts for the m20. i know all the hows just not the wheres.......
i ned to know all the best parts adn where to get them. the goal for this car is mostly track but occasional street buiild to reliavbly handle 450-500hp. i figure 450hp and then meth. so somewhere in the 450-500 range.
parts.....
mahl, wiesco or JE? should i ceramic coat them?
where do i get seals, gaskets, bearings etc from?
i already know about machine work.
are things like cryogenic process a benfit or na not really for m application?
are other coatings/prosseces better than ceramic?
ignition
plugs
wires
arps
is the war good enough or should i go another rout
what comprssion ratio should i shoot for?
anything else im missing?
basicly i want to have a car that is fun fast and reliable so help me over the next year put together a list of components that will accomplish this.
thansk for your help in advance you all have always been very nice and helpful. thansk gents
hx35
blowoff valve
charge tubing
WAR chip
parts.....
ignition
plugs
wires
arps
