Hey r3v.
So lately I've had cooling problems with my car. Just recently I've bled my coolant system 3 times in the past week. The reason being my engine overheats relatively easy. I just went on a test drive and I checked my coolant level which was fine. I squeezed the tubes to check for air and the highest hose had no coolant whatsoever inside. I could tell because it was really easy to squeeze and usually when I squeeze any other tube you can hear slushing of the coolant inside the hoses. I thought that this was odd so I drove it 10 miles; 3 miles on the road and 7 on the freeway.
The heat gauge never went past a quater of the way, which is good, but im still confused. It is ok to have some are in the cooling system or do you not want any air at all? I can't seem to get all of the air out no matter what.
When I bleed the system I turn the heater on full blast, bring it up to operating temp, then I open up the valve and rev the engine to 2000 RPMS until I stop seeing air bubbles. I don't use the normal bleeder valve because the bolt is stripped, so I use the 19mm hex bolt closest to the radiator to bleed is which I was told is fine to do. I guess on autos there are sensors connected to those bolts.
Even after all of that there is still air in the system. I want to fix this ASAP because it's starting to get hotter outside and I don't want to have to worry about my car overheating.
Thanks.
Thanks.
