Diesel sound normal for M20?
  • BROKINBIMMER
    • Nov 2012
    • 195
    My M20 sounds like a diesel engine. So far I have adjusted the valves, changed oil with 20/50, changed the exhaust manifold gaskets along with new hardware, and replaced the exhaust from the cat-back. The motor is still very noisy and its driving me nuts.
    Suggestions????
  • travish325
    • Jun 2012
    • 1151
    Buy a newer car?
    • willworkfore30s
      • Aug 2011
      • 1090
      Sounds like you most likely have a perfectly running m20
      • Cletonius
        • 2809
        I dunno man, my car is pretty quiet.
        OP: what did you set valves at?
        - Josh
        1990 325is
        Need a shift boot?
        Looking to buy shift boot frames, PM if you have one to sell
        Here's what happens when you let the internet pick your license plate
        • BROKINBIMMER
          • Nov 2012
          • 195
          Originally posted by cletonius
          i dunno man, my car is pretty quiet.
          Op: What did you set valves at?
          .010 with engine cold...
          • Cletonius
            • 2809
            You can go a little tighter if you want, where did you put the feeler gauge? Cam side or valve side?
            - Josh
            1990 325is
            Need a shift boot?
            • BROKINBIMMER
              • Nov 2012
              • 195
              http://spece30.com/forum/42-engine/3...t-values#45918
              Valve side, would you recommend otherwise?
              • Cletonius
                • 2809
                Yes, put the feeler between the cam and rocker. It's possible the end of the valve is cupped, causing inaccurate measurements.
                - Josh
                1990 325is
                Need a shift boot?
                • ZM Blue Devil
                  • Dec 2006
                  • 13836
                  properly running m20 is the most beautiful sound in the world. While there will be "ticking", but more like a smooth sewing machine not a diesel. Maybe you have a 324td?
                  Levent
                  %20levent@gutenparts.com
                  Ladies:
                  • BROKINBIMMER
                    • Nov 2012
                    • 195
                    Well, what is the gap supposed to be between the cam and rocker?
                    This gap can't be the same as adjusting the gap between the rocker and valve...
                    • DaButt
                      • 476
                      lol I had the same question after I got my valves adjusted. The guy who did them for me noticed the noise, too. so he went back in, re-adjusted all the valves, then tried again. Same noise.
                      That was over a year ago.
                      /______\_o_/______\
                      l{(OO)=[//][\\]=(OO)}|
                      \ #___======___# /
                      |__/-------------\__|
                      "Took me an hour to do this..."
                      took me like three seconds to copy/paste it- FOR SCIENCE!!
                      Barney Fucking Rubble
                      • Cletonius
                        • 2809
                        Why can it not be the same?
                        When you set it at the valve the rocker is in firm contact with the cam, same thing happens if you set it at the cam, the rocker is firmly pressed against the valve.
                        Science!
                        - Josh
                        1990 325is
                        Need a shift boot?
                        • BROKINBIMMER
                          • Nov 2012
                          • 195
                          Ok, little update. I found a broken stud that secures my exhaust manifold to one of the downpipes....
                          Would this cause an exhaust leak and make the engine sound like poop?
                          • nickmcc92
                            • Dec 2012
                            • 442
                            Yes it would.
                            My valves are set at .008 on the cam side. My motor isn't too loud once warmed up.
                            • BROKINBIMMER
                              • Nov 2012
                              • 195
                              It looks like the stud closest to the cylinder head on the forward manifold is broken. I'm thinking this would be a rather difficult removal. Would finding another manifold with good studs be a better way to fix this compared to trying to remove the broken stud?
