I have a 88ix. I recently was having an idle issue where it was revving up to 1500 and holding there. I figured this was probably a vacuum leak. I proceeded to replace the following just to be safe and it needed a tune up anyway
Injectors
Fuel rail
FPR
Fuel filter
All vacuum lines, boot, etc
Fuel line going to and from rail
Cap, plugs, rotor
O2 sensor <6 months ago
Now the idle speed is steady at 650-700. The issue now is that while the idle SPEED is perfect, the whole car is bouncing. The exhaust makes a "putt-putt" sound while it idles. When throttle is engaged ever so lightly, the RPMs dip to the point of almost stalling then goes back to normal. I took it for a 5-10 minute drive and it felt as if it was running with half power. This is quite troubling. I've read through many different posts. I cleaned the ICV, throttle body and AFM, still nothing. Checked for vacuum leaks, nothing. Anyone have any other ideas?
Injectors
Fuel rail
FPR
Fuel filter
Cap, plugs, rotor
