What radiator should I buy?
  • Dalejandrino
    • Feb 2012
    • 307
    Hey r3v,
    So I need to replace my radiator, and I don't know whether I should go with a factory or aftermarket radiator. I'm sure the majority of you would say OEM, but if any of you know of a radiator that performs better I would appreciate it if you pointed me in the right direction. I have a 1987 325is btw.
    I found this radiator on the ireland engineering website:
    (If I got this I would probably do a late model cooling system conversion)
    And another I think it's the same as stock though...
    -1987 325is coupe(SOLD)
    -1990 325i sedan
    For a street car, the OE/OEM radiator is fine.
    • dnguyen1963
      • Nov 2011
      • 2648
      I have CX Racing in my car. All aluminum and works great.
      • digger
        • Nov 2005
        • 6075
        A Behr one is fine, i used my car in 115F last summer with no issues with an engine that puts out more heat than stock
        • Dalejandrino
          • Feb 2012
          • 307
          http://www.cxracing.com/mm5/merchant...gory_Code=RDBM
          If i we're to install this would I have to get a new fan and hoses?
          -1990 325i sedan
          • dnguyen1963
            • Nov 2011
            • 2648
            No, it is a direct replacement of OEM radiator.
            • Dalejandrino
              • Feb 2012
              • 307
              But the holes look like their in different spots than oem. I have an early model.
              -1990 325i sedan
              • s14pwd
                • Apr 2012
                • 116
                The issue with the OEM or Behr rad is the plastic end caps tend to leak or crack over time. This may not seem like a big deal until they just let go and somehow the coolant works its way to the tires... (Which BTW happened to me)
                OP I would say go with an all aluminum rad just for that.
                • s14pwd
                  • Apr 2012
                  • 116
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    CX Racing rad is for '88 and later model, I think.
                    • Dalejandrino
                      • Feb 2012
                      • 307
                      Do you know where I can find an all aluminum radiator?
                      -1990 325i sedan
                        Well yeah, this being true for every modern radiator that isn't all aluminum or all brass. But if replaced on schedule (every 10yr/100k) along with the water pump, expansion tank, cap, fan clutch, thermostat, and all hoses the chances of a failure are remote. Assuming there aren't head gasket problems and over pressure conditions.
