Not sure whats in my e30 help!!
  • norwood e30
    • Mar 2007
    • 442
    The motor in my car isnt original i been all over different fourms websites and ebay the numbers i found on the block 1278 921 280 87 i really hope that helps i miss driving this car so if anyone can help i would really appreciate it thank you.
    norwood e30
  • Vivek
    attention whore/retard/bitch
    • 6167
    Post a picture and use punctuation please. Do you have any idea what is wrong with the car?
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • dnguyen1963
      • Nov 2011
      • 2651
      He did have a period at the end.
      • norwood e30
        • Mar 2007
        • 442
        ^^^ lmao
        • SpecM
          • Oct 2005
          • 4531
          a pic will help
          1989 cirrisblau-metallic 325i
          • norwood e30
            • Mar 2007
            • 442
            Sorry about that. My car is a 1989 bmw 325i and the original motor that came with the car was blown. NOw the engine the car is from a e28 528 the year i believe is 1988. Im trying to see if it is a eta motor or a seta. So i can make sure i have correct wiring parts ect.
            • SpecM
              • Oct 2005
              • 4531
              if it is indeed an engine from an 88 528e, it is a super-eta. electricly speaking, the wiring/sensors are the same. 99% of the standard replacement parts likely needed for repairs are the same too.
              • norwood e30
                • Mar 2007
                • 442
                Now the problem Im having is that i can crank the car but it will not turn over. The engine wiring harness came out of a 1989 325i auto/transmission. My car is a standard transmission. I also Have two Ecu's
                1.computer: bosch 0 261 200 173
                2.computer: bosch 0 261 200 153
                  Those are DME's for an M20B25 engine.
                  • SpecM
                    • Oct 2005
                    • 4531
                    ^ but they will run a s-eta just fine
                    • norwood e30
                      • Mar 2007
                      • 442
                      @ specM I just came from outside see what cylinder head was on the block.
                      cylinder head: 05 885
                      • norwood e30
                        • Mar 2007
                        • 442
                        This has has to be a super eta motor
                        • SpecM
                          • Oct 2005
                          • 4531
                          yep
                            While some things suggest that this could be a SuperETA, I would not go so far and to say that it has to be. Without certain knowledge of the car the engine came from and what might have been done during the swap, you can't say exactly what is in the car now. External evidence may help, but you'd have to see the piston tops and measure the stroke to know if the short block is a SuperETA.
                            • norwood e30
                              • Mar 2007
                              • 442
                              @jlevie I went on ebay to see if they had a similar motor. And the cylinder head matched mine. And the first 7 numbers on block matches my block 1278 921 it was a long block that fit following bmw
                              1988 - 1988 BMW 325 2DR (E30) Single overhead cam engine
                              1988 - 1988 BMW 325 4DR (E30) Single overhead cam engine
                              1988 - 1988 BMW 325e 2DR (E30) Single overhead cam engine
                              1988 - 1988 BMW 325e 4DR (E30) Single overhead cam engine
                              1988 - 1988 BMW 528e 4DR (E28) Single overhead cam engine
