Fuel hose to FPR?
  • osubeaver
    • Jan 2010
    • 35
    Fuel hose to FPR?
    I installed a new FPR, and the fuel supply hose connecting to the FPR looks like it had some cracks. Initially there were no leaks, but today on my way to work I could smell gas.
    Can I replace the hose with a generic length of fuel hose from NAPA? Or should I order a BMW specific part? If generic, what size hose would I need?
  • 603Racing
    • Dec 2010
    • 612
    Drive your car to NAPA (or other), explain what you need, they can match the hose.
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    • ttrousdell
      • Nov 2009
      • 1770
      D8x13. Inner and outer diameter in mm of the hose. I cant see why getting a hose of those dimensions rated for fuel of another manufacturer would be a problem.
      The Build:
        You can use generic 5/16" fuel hose for the line that connects to the FPR as it is not under pressure. But you must use hose rated for fuel injection service for the high pressure parts of the fuel system.
        • dnguyen1963
          • Nov 2011
          • 2651
          Blunttech sells 5 m reel for $45.00. You should replace all your fuel hoses.
          • osubeaver
            • Jan 2010
            • 35
            thanks for the responses! I may use Jlevie's suggestion to get me through the week, and then order the hose from blunttech for the larger project.
              • 37834
              There's no need to order OEM hose. The 5/16 fuel injection hose is just fine.
              Grover Beach, California
              BimmerHeads.com
              • dnguyen1963
                • Nov 2011
                • 2651
                5/16 NAPA fuel injection hose is more expensive than Blunttech, at least locally. But, if you need just a short section then go for it.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I bought 5m from autohausaz for $32 and regardless of what the pressure in the line is you should huge fuel injection rated hose since it will stand up to ethanol whereas standard fuel line will not.
                  Alice the Time Capsule
