m20b25 oil line bypass?
  • CrJdMc
    • Feb 2012
    • 195
    Hey all! i have an 87 is i am working on, i thrashed my oil cooler on the side of the road, and all i could do was cut the lines before the cooler, and get hose, and "bypass" it. ANd i now found that where the line goes to the oil filter housing IS JB WELDED!! So i was wondering, should i get new lines? They are expensive and im on a high school students budget, I also heard that you can use a eta oil filter housing to delete the lines? anyone know about this? thanks!
    sigpicInstagram: bir_madhatter
    Add me on Facebook: https://www.facebook.com/connor.mcco...57?ref=tn_tnmn
    • 37829
    You can install the male oil filter adapter from an Eta engine and install the oil filter directly against the block.
    Part number is 11112140435 and it's about $9 new.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • CrJdMc
      • Feb 2012
      • 195
      Heck yes. Thank you so much!
      • CrJdMc
        • Feb 2012
        • 195
        So this will completely get rid of the lines as well?
        And all i have to do is take the filter off the filter housing, and put the adapter in? How will this bypass the lines? sorry to flood with questions, just trying to make sure before i go tear into this. thanks again.
        • SmokeE30
          • 1730
          That piece is all you need to ditch the adaptor on the block the lines attach to. Simply pull the whole oil cooler setup off and mount filter directly to the block with the above listed adaptor
          Shawn @ Bimmerbuddies
          Bimmerbuddies LLC
          717-388-1256
          2971a Roundtop Rd, Middletown PA 17057
          bimmerbuddiesllc@gmail.com
          • SkiFree
            • Jun 2011
            • 2766
            Like so ..... (took this pic yesterday).
            ADAMS Autosport
            • CrJdMc
              • Feb 2012
              • 195
              Thanks a lot guys!
              • ///M42 sport
                • 3952
                how many of you guys out there do this?
                • SpecM
                  • Oct 2005
                  • 4531
                  I did on my b25. simplified things and makes oil changes easier/cleaner
                  1989 cirrisblau-metallic 325i
                  • FLG
                    • Sep 2011
                    • 3165
                    Ski please remove that fram filter before it explodes.
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • CrJdMc
                      • Feb 2012
                      • 195
                      Anyone know how to take the oil filter housing off> just the bolt in the center?
                      • TobyB
                        • 5256
                        yup.
                        t
