Need some advice!
  • dillon7
    • Mar 2013
    • 824
    Need some advice!
    ok so I'll just cut straight to the chase.
    I bought an e30 with a broken timing belt. I got the valve cover off and immediately noticed a broken rocker arm. I'm assuming it has bent valves as well.
    So my options are:
    1. replace the head the another 325e head (not doing the stroker)
    2. swap an engine
    Guess my options for the swap are another eta engine :zzz:
    or an i engine or possibly at m50.
    I'm pretty tight on cash so that's always deciding factor.
    Your input is greatly appreciated.
    Instagram: @dillonmakar
    Build thread HERE
  • Swanny
    • Mar 2012
    • 2834
    I have an e head if ya need one!
    Swanny!
    SUCKERS.
    • dillon7
      • Mar 2013
      • 824
      pm me with info and price!
      that's probably what I'm going to do as long as the pistons are fine.
      Build thread HERE
      • Swanny
        • Mar 2012
        • 2834
        Def the easiest.. Pm coming your way.
        Swanny!
        SUCKERS.
        • dillon7
          • Mar 2013
          • 824
          with the 88 model having a different redline than previous years does that mean I can only use an 88 325e head for a direct swap?
          Build thread HERE
          • dillon7
            • Mar 2013
            • 824
            never mind answered my own question.
            so now should I just go ahead and do the 325i head? It seems like that would be easier to find than an 88 325e head.
            Build thread HERE
            • cmcgrogan
              • May 2013
              • 240
              the i head is probably your best bet. a simple upgrade if you have to replace the head anyway. it will cost you a bit more, but there are more cams, better designed head if you are in the redline a lot.
              Originally Posted by scaraveos
              Are saying about welding the head to the block? and if yes how is it seperated if required?
              (possibly a stupid post)
              • dillon7
                • Mar 2013
                • 824
                I'm sounding like an idiot. But since the super eta already had an i head on it wouldn't just any i head bolt right up without anything else?
                Build thread HERE
                • TobyB
                  • 5298
                  Take it apart, replace the broken and bent parts, put new valve stem seals on
                  all 12, lap the valves if they're looking ugly, and drive it.
                  $2-300, MAX, but quite likely $150 WITH the head gasket kit.
                  Checking the valve springs (uprating to i spec?) would be worthwhile.
                  Oh, spring for a new belt and tensioner, too.
                  Really. If the backs of the rocker rod supports in the head survived, the head's almost certainly undamaged.
                  The tops of the pistons will have knicks in them, but unless they're pounded, they'll
                  be fine. That's what I'm racing right now. It's slow, but it works.
                  Really. A bit more work, a lot less money.
                  t
                  • dillon7
                    • Mar 2013
                    • 824
                    t
                    Thanks for some helpful information.
                    The pistons have nicks in them and a rocker arm was completely broke off so I kinda assumed my head was toast.
                    So what I've got so far is that I CAN'T just swap a 325i head on without doing intake and ECU?
                    Build thread HERE
                    • Swanny
                      • Mar 2012
                      • 2834
                      Oh you totally could, but to get the most out of the I head you need those. If not it'd act exactly like your seta.
                      Swanny!
                      SUCKERS.
                      • dillon7
                        • Mar 2013
                        • 824
                        Oh ok perfect. I just need to get it running again, I'll
                        Worry about power after that.
                        Build thread HERE
