M20 block
  • dwight
    • Dec 2012
    • 550
    M20 block
    What is the safest bore and largest bore an m20 block can be bored?
    Thanks
  • Poorboyz
    • May 2012
    • 2117
    Are any of the cylinder walls scared? What is the reasoning why you're wanting to bore it?
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • dwight
      • Dec 2012
      • 550
      rEPLY
      Looking to put in over sized pistons, no scars engine had 550K miles on it and still ran but compression was dropping. lOOKING TO DO THE FOLLOWING
      s-52 CRANK
      135MM RODS
      86MM PISTONS
      284 CAM
      USING MY M20 BLOCK AND 885 I HEAD
      THANKS FOR YOUR INTEREST
      • digger
        • Nov 2005
        • 6215
        86 is pretty safe, abs max i heard was 87mm
        • dwight
          • Dec 2012
          • 550
          Thanks Digger for your input.
          • MattAvino
            • Jan 2011
            • 2147
            ooh look, a local
            E30 buildy things
            http://www.r3vlimited.com/board/showthread.php?t=195286
            • SkiFree
              • Jun 2011
              • 2766
              I tend to agree here, however the power difference between an 85mm bore and the same pistons in the 86mm is not enough to warrant much stress or thought. 87mm in my opinion is on the "not worth it" side of the "power vs risk" sliding scale. The only way I'd do it would be on a race engine which I wouldn't expect to last.
              ADAMS Autosport
              • dwight
                • Dec 2012
                • 550
                Thanks for your reply ski free.
                • digger
                  • Nov 2005
                  • 6215
                  there are some very good reasons for a bigger bore (not just a small cubic inch increase) but you need to consider the subtle details to get it to work otherwise the losses can outweigh the benefits.
                  when i spoke to MM they said there is plenty of meat to do 87.5mm in the walls but limiting to 87mm allows a margin for rebore. they have done many 87mm bored engines but usually limit things to 86mm to be able to use the stock headgasket and that is the only reason. having seen how close the oil gallery is to the bore i wouldn't be thinking about 87mm at all
