100+ oil psi on my rebuilt m20
  • FLG
    • Sep 2011
    • 3165
    Same setup as well rc
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • bmwstudent
      • Sep 2011
      • 1364
      You should not be restricting a 1/4" (4an) line to your turbo. Period. If you are, you are reducing or restricting the amount of oil to your turbo. That said, I don't believe it would raise your oil pressure even if you did, if your pressure relief valve is operating properly it should dump all excess pressure in the system. I work on turbo motors everyday, none of them have restrictors or reducers in the oil feed line. Why would you reduce or limit the amount of oil you have entering the turbo?
      • Northern
        I like cupcakes & sh!tboxes
        • 5248
        Its a commonly brought up "fix" to a smoking hx35/h1c, although a -10 or larger drain should be the proper thing to do first. I do not have a reducer on the -4 feed of my hx35/40.
        A restrictor should drop flow/pressure after, but it isn't going to raise the pressure before it any more than if you werent running that feed line in the first place.
        I'd put money on a faulty gauge/wiring/sender, or relief valve.
        Originally posted by priapism
        Originally posted by shameson
        • Kozworth
          • May 2011
          • 1339
          Ok, I will double check the wiring and gauge components first. I think what I was getting confused is the pressure vs. volume of oil. I am probably just going to drill the reducer so I do not have to worry with getting a fitting that fits perfectly online.
          • lcoleman
            • Jan 2009
            • 331
            I used whatever restrictor ATP sells (.035 maybe?) on my GT30 on a -3AN line with no ill effects. It had about 25psi at a hot idle. Ball bearing turbos often need to be restricted, journal bearings often do not.
            • Kozworth
              • May 2011
              • 1339
              I am condemning the gauge. The car sat for days, with power the gauge goes straight to 100psi, with the 12v off it goes to zero.. I also had a weird fluctuation around 20 ish.. so I got to diag that now.
              • lcoleman
                • Jan 2009
                • 331
                Mine pegged when the signal wire was shorting to ground.
                • Kozworth
                  • May 2011
                  • 1339
                  Funny.. turned out the wire from the sending unit was touching the header ever so slightly, melted the insulation and the wire was shorted on the header.
                  Moved the wire a bit, and she reads nice, around 50psi.
                  • ak-
                    • 12422
                    I knew it was a ground issue lol.
                    1991 325iS turbo
