is this a big deal?
  • LimoBob
    • May 2013
    • 16
    is this a big deal?
    I looked at (potential purchase) an 88 325i w/ 130k that had some ticking/tapping noise coming the top end area after start up and idle. After about a 10 min test drive the noise was gone, eng sounded fine. lifters? exhaust leak? a rod noise wouldn't go away would it? the car apparently is no longer a daily driver (maybe driven once a wk). How concerned should I be? Overall, you can tell the 1 owner car has been well taken care of. Before I purchase it, i'm having the noise diagnosed by a tech. Any thoughts?
    The valves probably just need adjusting. A bad rod bearing will make more noise on a hot engine (thinner oil). Piston slap will be worse when cold and may go away when the engine is hot, but at 130k that is unlikely.
    • LimoBob
      • May 2013
      • 16
      thanks jlevie! a valve adjustment remedy would be great
      • bangn
        • Sep 2011
        • 760
        just your typical m20 ticking valvetrain. If its loud it will need a valve adjustment but chances are the ramps on the rockers are worn. Nothn thats going to go bang
        Boris - 89 E30 325i
        84- E30 323i
        • LimoBob
          • May 2013
          • 16
          So I'm being told by mechanics that my valves are hydraulic and not adjustable; I'm confused!
          • dnguyen1963
            • Nov 2011
            • 2649
            '88 325i does not have hydraulic valves. Get a different mechanic.
            • LimoBob
              • May 2013
              • 16
              I hear ya.
              • gtdragon980
                • Jun 2008
                • 1808
                Lol tell them to go waffle themselves! Go to a BMW specialist if you want to have them do a good job!
                FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                Originally posted by scabzzzz
                I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                1989 325i - Project/weekend driver
                2002 325i - DD
                2005 Suzuki SV650 - Toy
                • Pootis
                  • 636
                  Remove your white glove and slap that mechanic across the face
                  1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                  COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                  • TobyB
                    • 5243
                    exhaust leaks 'tick', too, and get better when hot...
                    t
                    • bangn
                      • Sep 2011
                      • 760
                      lol next he will say your pushrods are worn
                      Boris - 89 E30 325i
                      84- E30 323i
                      • Thehemiman
                        • Apr 2009
                        • 533
                        If this is the case I'd suggest the lsx pushrod retrofit.
                        1988 325i Vert
                        1991 318is Slicktop
