M20b23 with an m20b25 head?
  • Pdxseth
    • May 2012
    • 3124
    Can I do it? I was going to put it on an m20b27 but if this would be better(maybe higher compression) it is now an option for me.
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    Lower compression, lower displacement. Not worth it imo
    -Andy
    • digger
      • Nov 2005
      • 6182
      i think you'll end up with a nasty step as the 885 chamber is 84mm round and the b3 is 80mm bore.
      the 731 ports are big enough for a b23, and it has the correct flat squish band. a cam works ok in the b23 they have higher CR than most of the factory m20
      • Pdxseth
        • May 2012
        • 3124
        So now the question is: what to do with the euro car? Rebuild/upgrade the b23 or put the 2.7i in?
