2.7i Conversion......spark plug wires.
  • red325ix
    • May 2007
    • 344
    In the process of converting my 86es to a 2.7i motoronic 1.3.
    The "i" spark plug wires that I've sourced are a bit haggard. The set I was running on the ETA are a nice 8mm set so I'd like to reuse them if possible.
    Is there any reason why I couldn't just take the pulse generator pick up off of the "i" set and use it with my nice ETA wires? I don't see the difference.
    Thanks guys
  • E30-325iS
    • Sep 2011
    • 191
    That should work fine.
    • acolella76
      • 2950
      There's really no way to get that thing off of the wire... but if you find a way that works, let us know!
      -Alex
      • red325ix
        • May 2007
        • 344
        Its offered as a separate part number in the parts catalog. The boot should come off somehow without damaging it.
        • red325ix
          • May 2007
          • 344
          Or maybe just cut and re-crimp it
          • FLG
            • Sep 2011
            • 3165
            If you can remove it good luck. FYI the car will run without it, mostly fine, some have a bit of off idle stumble. Basically only purpose is to fire the injectors in batches, removed it will simply fire them all at once.
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
