1989 325is with stock M20B25. Gauge worked perfectly for a while, then it was dancing around (like it had a loose ground on the back of the cluster,) and stopped completely altogether and now sits right below the cold (as if it weren't even turning on.)
I installed a new temp sensor and a known working gauge and it still isn't doing anything. What is the resistance supposed to be on the plug coming from the harness? It almost screams a grounding issue, but I'm not sure.
Thanks.
Thanks.
