"Secondary" Thermostat, near firewall.
  • kid325e
    • Sep 2007
    • 6422
    REFERRING TO THIS THREAD http://www.r3vlimited.com/board/show...72#post3763172
    Looking at what you guys' are doing about these "Secondary" Thermostats.
    Apparently it was a recall they installed in our cars to keep HOT COOLANT from spraying all over your feet? How many of you guys are keeping these, and what you doing to "delete" or relocate them? I'm going to cross this thread into the Track sub forum as well.
    Hoping to see some creative answers! Thanks for your time.
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    I delete that mess on any car that has it. The only case where it would be needed is if the driver is brain dead and doesn't shut down the car when the needle approaches the 3/4 mark.
    • kid325e
      • Sep 2007
      • 6422
      Jlevie to the rescue again.. Thanks.
      Simple question here.
      Does this hose, replace the monstrosity of hoses that connect to the "Secondary" Tstat? I have this hose at home, ready to install, just wanted to make sure I wasn't going to mess anything up.
      Here's what I pulled off the car.
      - Description of the hose in question..
      http://www.ecstuning.com/Search/Site...22743/ES24930/
      Thank you guys so much, especially Jlevie, your help with my project car is invaluable, as is the piece of mind getting it from you. Kudos.
      clutchCTRL!
      - 2000 323i AT
      • kid325e
        • Sep 2007
        • 6422
        I'm confused because what I removed has 4 hoses, the new one has 3...
        clutchCTRL!
        - 2000 323i AT
        • TobyB
          • 5266
          no, that's the filler hose, you still need that.
          There are now a mess of hoses in the parts system-
          some keep that t- stat, others let you remove it.
          Originally, BMW cut the long hoses and spliced that
          t- stat in there. There's not really much room for it.
          I ended up with more hoses than I needed- same problem.
          t
          • kid325e
            • Sep 2007
            • 6422
            t
            Talked to my boss and came up with a solution. This is a drift car i'm building, I plan to remove the heater core here soon anyway.
            Im going to pick up a BMW hose (ill grab the PN when i'm at work.) and connect it from the pipe at the rear of the head, to the pioe at the bottom of the Tstat housing and call it good. Less hoses, less clutter, less clamps, win win for this car IMO.
            Sent from my GT-P5113 using Tapatalk HD
            clutchCTRL!
            - 2000 323i AT
            • TobyB
              • 5266
              ...and no heater core to pop and cook your feet. One more win!
              t
                • 37832
                x2, I do the same.
                It's pretty easy to "delete" this thermostat. Just order new hoses for the car and install them. ;)
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • FLG
                  • Sep 2011
                  • 3165
                  Block the heater hoses. Don't loop them. By design ghey bypass the thermostat and you'll be circulating hot coolant back thru your engine.
                  Sent from my Galaxy Nexus using Tapatalk 2
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
