Swapping out head bolts for ARP studs without removing head - How??
  • saturnv7890
    • Jan 2011
    • 696
    SEE RESOLVED STEPS ON LAST POST
    (I bought the studs because I want a reliable daily driver)
    Hey all,
    I want to switch to ARP head studs because the car I’m driving will be my DD and I don’t want to start blowing headgaskets. It’s a relatively new headgasket so I would like to try and just swap out the bolts for studs without having to completely remove the head.
    Facts:
    -300 miles on engine/HG
    -O-ringed block
    -10 psi max
    -2.7i seta stroker ~8.5:1 CR
    -torx head bolts
    My understanding of how to swap the bolts:
    1) Start from center (cyl 3 and 4), work outward
    2) Remove the first bolt completely
    3) Torque new head stud down – completely to 80 ft-lbs?? or 60 the first shot around??
    4) Repeat steps 2 and 3 working outwards
    5) Then increase torque in same pattern until you’ve reached 80???
    Questions:
    -Do I need the studs? (For my goal of reliability and boost level)
    -Can I swap out just the bolts without removing the head?
    -Will just swapping out the bolts hurt anything and make it less reliable?
    -How should I do this? (do my steps above need to be modified?)
    -How much should I torque down the head studs? I’ve read 80 ft-lbs
    My Transaction Feedback
    My "build" thread
    BUY MY CAR!!
  • bimma360
    • 1940
    Although I can't answer all of your questions, I can say that my Dinan turbo has been just fine for the last 70k miles (after rebuild) with stock head gasket and stock bolts @10-11psi. To this point I've had no coolant loss and no oil burning at all. I also don't beat on it everyday, so that may have something to do with it. If I'm not driving very hard the car rarely sees any boost.
    E30 Dinan Turbo
    • saturnv7890
      • Jan 2011
      • 696
      Well I decided to spring for them as a cheap peace of mind.
      I do plan on beating the car.. at least for a little while haha. For me I bought the turbo to enjoy the crap out of! Not to say enjoying responsibly isn't worse by any means! (I mean.. look at all those commercials!)
      So now the question lies in the installation, can anyone input?
      My "build" thread
      BUY MY CAR!!
        • 37833
        I know kamotors did this when he first boosted his E30. You can PM him for details.
        Grover Beach, California
        BimmerHeads.com
        • saturnv7890
          • Jan 2011
          • 696
          Thanks! Shot him a pm
          My "build" thread
          BUY MY CAR!!
          • Bullet Ride
            • Dec 2010
            • 598
            I did this as well on my turbo car. Worked fine. However I just torqued each one to spec as I did them.
            • saturnv7890
              • Jan 2011
              • 696
              Thanks! I guess ARP says 70 ft-lbs. So you just removed one, torqued it to 70, rinse, repeat?
              My "build" thread
              BUY MY CAR!!
              • kamotors
                • Nov 2007
                • 7102
                PM sent, I've done it on 2 E30's with zero issues.
                7speedshop.com
                • saturnv7890
                  • Jan 2011
                  • 696
                  Thanks for all the help!! Waiting for these to come in, I've been dropping all kinds of money on this thing haha
                  EDIT:
                  I swapped them out successfully without issues so far.
                  Steps I took:
                  -Following the torqueing pattern, I started from the inside (between cyls 3 and 4) and worked outwards
                  -Removed the first old head bolt
                  -Cleaned everything nicely, put stud in "hand tight" as specified by arp
                  -put included arp assembly grease on clean washer, clean nut, and clean stud
                  -torque nut to 70 ft-lbs
                  -repeat process for each bolt (one at a time!!)
                  -Once I was done with all 14, I went back and re-torqued to 70 ft-lbs (in specified pattern)
                  -Ran car for a 30 minute heat cycle, I didn't go too hard on the motor
                  -Went back and re-torqued to 70 ft-lbs at same pattern
                  NOTE: These steps are for replacing old bolts without removing head. This is not for a fresh installation!
                  My "build" thread
                  BUY MY CAR!!
                  • andrewm
                    • 456
                    Im curious, has this still been working well for you?
                    1987 Delphin 325e Sedan - Natalie
                    1990 325i 24v
                    1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      Did any of the fasteners loosen at all, or where they still close to 70 ft/lbs?
                      1997 Artic Silver M3
                      CES GT4094r 651hp/615tq @ 24 psi
                      • AbsorbantNut
                        Non faccio funzionare questa merda
                        • Jun 2010
                        • 2491
                        Thought I'd chime in here. I installed the studs one at a time according to these instructions and have had 0 complaints. I also re-torqued the head after a 40 min heat cycle. I plan on re-torquing the head again over break so I'll post back if anything loosened up...not that I see a reason why it should :p
                        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
