Oil Temp/Pressure Gauge Idea
  • cganne
    • Jan 2010
    • 103
    Current Oil Pan gasket needs to be replaced and the existing drain plug was stripped at some point (previous owner) and has some weird gasket drain plug set up but works. I have an Oil Temp and Pressure gauge that I have yet to set up. I've seen Mishimoto has a sandwich plate for NPT connections for about $100. The other debate is buying a new oil pan for $200ish and having a shop put in NPT adapters since I have to pull the pan anyways to replace the gasket.
    Thoughts?
  • FLG
    • Sep 2011
    • 3165
    I have my oil pressure teed of the stock sending unit location, oil temp using drain plug with temp sensor
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • vpilarrt
      • Jun 2006
      • 2096
      You can't get oil pressure from a sender on the pan. I have both my pressure and temp on a block connected to the stock pressure location. Others have drilled and tapped a hole in the end of the filter adapter plate center bolt for their senders.
      • ak-
        • 12422
        Buy the sandwich plate in eBay, not mishimoto.
        It's the same thing but like 70 bucks cheaper.
        Don't get an anodized collored one = bad ground.
        1991 325iS turbo
        • 603Racing
          • Dec 2010
          • 612
          Buy a splittler block that goes into the stock pressure switch location. I use one on my DD and my race car.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
          • reelizmpro
            • 9543
            Temp and pressure from the pan is a bad idea. I know companies marketed drain plug sensors in the past but that was for convenience. The pan by design is an air cooled heat sink. On my 325i, the temp sensor in the pan read about 15 degrees cooler than the actual temp at the block/oil filter housing.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • cganne
              • Jan 2010
              • 103
              Thanks all, I bought an ebay sandwich plate but the fitment was not tight and I didn't want to risk it. Thought paying the extra $70 for the brand may make a difference.
              • ak-
                • 12422
                Where'd you buy yours from?
                Mine hasn't leaked a drop thru 2 oil changes.
                1991 325iS turbo
                • cganne
                  • Jan 2010
                  • 103
                  Not sure, it was through eBay though, was about a year or so ago. If I remember correctly the center seemed that it needed to be bored about 1/1000th more to fit. Haven't messed with it in awhile but now thinking I might as well.
