M20 camshaft lift measurement
  • salty
    • Apr 2013
    • 29
    hey guys
    i have a high lift camshaft from a friend which i dont have any idea about the brand or the lift degree :|
    i dont really care about the brand i am more interested in the degree
    i was searching around to find out and i cam up with this
    went for a second search for the rocker arm ratio i found a lot of different answers but the most common was 1.25
    can anybody confirm on my conclusion
    please correct me if am wrong
    thnx
    96 E36 2dr 325is SC - Rip
    89 E30 2dr Mtech M50b25 SC - Rip (wasn't driving)
    90 E30 4dr Mtech m52b28 - parted out
    91 E30 2dr Mtech m20b25 - sold
    90 E30 4dr Mtech m50b25+ - current
    94 E36 2dr 318is - sold
    92 E36 2dr 325i 1jz-gte - Drift missile
    88 E30 4dr 320i - current Daily
    instagram @qammazy :nice:
  • e21jps
    • Aug 2011
    • 44
    its not so easy on an m20 because the ratio changes as lift rises. You really need to install the cam in an old old fit a light valve spring set the correct lash and rotate the cam with a dial gauge on the retainer, its the only way to get a true measurement.
    If you have a degree wheel you can fit this to the front of the cam and measure the duration too (need to double the number to get crank degrees) Then you will know exactly what cam you have. Just measuring the lift gives you some indications but doesnt really tell you a lot.
    I sell ITB's and performance parts www.racehead.com.au
    e21 race car m20 power! 293Whp atmo 2.9
    details here http://e21jps.webs.com
    drive by video http://www.youtube.com/watch?v=kOdPbErYlho
    incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
    incar video http://www.youtube.com/watch?v=aQyvDR-B00A
    drag racing http://www.youtube.com/watch?v=7XmznH6PND4
    • TobyB
      • 5296
      What e21 said. The only real way to compare cams is to degree them in a head.
      I measure valve lift and timing, and ignore the rest, as I don't make cams.
      Honestly, it's almost easiest to do it when the engine's together- then you
      stick a timing wheel on the nose, a dial indicator in- line with the valve, and roll
      it over 720 degrees.
      The issue is that our 'tappets' have that curved shape, so when the lobe
      goes up the inside, the ratio's lower (as in, 1:1.2) and as it goes off the outside,
      it's a lot higher (like, 1:11.3) But it's not quite linear... and inlet valves are on
      one side, while exhausts are on the other.... so in- head just eliminates a lot of variables.
      t
