new battery no start plz help!!
  • Trptguy
    • Aug 2007
    • 799
    ok tried everything, fuse is good....connections seem good and tight....sigh
    • Gregs///M
      • Mar 2012
      • 2459
      Make sure your engine ground is in good condition and clean and secure. It runs from the oil pan to the frame rail on the drivers side. It is the engine ground for all engine electronics including the starter.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • Trptguy
        • Aug 2007
        • 799
        what does the eingine ground look like
        • Cabriolet
          • 9620
          it's a 6" wire that runs from the front of your oil pan to the driver's side of the car.
          im thinking something else is wrong tho. like did you try jummping your car from another car with this battery connected?
          Much wow
          I hate 4 doors
          • Trptguy
            • Aug 2007
            • 799
            i did that with the last battery that was dead........what is wrong with that???
            • dnguyen1963
              • Nov 2011
              • 2649
              It could be this...
              CAUTlON
              On models equipped with on-board computers,
              remove the computer fuses (fuse no. 1 0, 12, 21,
              and 27) prior to quick-charging to prevent damaging
              the computer.
              • Trptguy
                • Aug 2007
                • 799
                Originally posted by dnguyen1963
                It could be this...
                CAUTlON
                the computer.
                ok so let's say I damaged the OBC, wouldn't the fuses also be blown?? Which they aren't BTW.
                Just so no one thinks I am being an ass, I do appreciate all of the help so far!!!!
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  Actually, it is the opposite of what you think. If all of your fuses stay intact, your OBC would be dead because there might be too much current flowing through them during a jump start. I have not had this happened to me so do not quote me for this, but I have heard that a dead OBC can prevent the car from starting. There must be a very good reason for Bentley to recommend the removal of fuses during jump start.
                  • Trptguy
                    • Aug 2007
                    • 799
                    shit! ok then i will check the OBC.....anyone got one for sale?
                    • Trptguy
                      • Aug 2007
                      • 799
                      another question, can i bypass the obc???
                      • Cabriolet
                        • 9620
                        the brain will be specific to your year and engine. there is a sticker on the underside of it. it will say XXXXXXXXXX then three digits like 173 or 143 u will need that info when replacing it
                        Much wow
                        I hate 4 doors
                        • Trptguy
                          • Aug 2007
                          • 799
                          wait isn't that the ECU???
                          • Cabriolet
                            • 9620
                            oh im not sure which one is dead for you. there are also 3-4 types of OBCs
                            Much wow
                            I hate 4 doors
                            • Trptguy
                              • Aug 2007
                              • 799
                              is the OBC absolutely necessary???
                                Neither the OBC nor the DME would affect most of the dash lights nor would they affect the rest of the car's lights. From the OP it sounds like battery power isn't reaching the car. Verify the battery's charge level (12.6-12.7v on a fully charged battery) at the battery posts. Then compare that to what you read from the battery positive to chassis ground. That is a check of the ground connection and should be the same as measured across the battery. From there start probing the primary power connections.
