Inspect C191 on your harness it controls your injectors. Mine was fouled and caused similar issues of bucking and missing. Feels like a spark cut?
NO START HELP (2nd page) and higher load/higher rpm feels like rev limiter
Already soldered the c191 to bypass it, what else could it be?Comment
Here's a log:
DepositFiles provides you with a legitimate technical solution, which enables you to upload, store, access and download text, software, scripts, images, sounds, videos, animations and any other materials in form of one or several electronic files.
I can't tell if it's a sensor issue or a fueling issue. Maybe an expert can see this from the log? I replace the cps with a vemo which blunttech swears is the same exact thing as the OEM one
OH! Is my fuel pump on its way out? My car was at about 1/8th tank and sputtering like it was running out of fuel. I read somewhere that a bad fuel pump has a hard time pulling fuel up on a low tank?
.Comment
Hard to say unless you have a fuel pressure gauge. Add some gas and find out.Comment
Like a dumbass I bought a fuel pump, the car won't even start now. I can hear it prime, it must've been part of the problem. Now maybe something in my tune is messed up?
It cranks and cranks and sometimes catches and immediately dies. I did get to run at like high revs but then it died when I started to let the throttle go.
Any ideas? Is my tune fucked? Please help me!!
This is starting to get me a little frustrated and I have places I need/needed to be.
Tooth log:
Log:
Tune:
If anyone could take a look at that data above that would be great!
I have some more info now after a busy weekend.
Fuel Pressure:
I put in a fuel pressure gauge, found that the fuel pressure won't stay after the system is primed (key clicked to "on"). It builds up pressure to 3 bar, then once the fuel pump stops, it goes back down to 0. Additionally, when I installed the fuel pressure gauge, the pressure line did not have much fuel left in it. It was certainly not under pressure. Is this characteristic of a bad FPR?
This video shows the behavior (processing right now.. should be up soon)
This is "IMG 1507" by Chris McCann on Vimeo, the home for high quality videos and the people who love them.
I have not tried to start the car yet now because I am unsure the megasquirt is consistently receiving an RPM signal from the cps (brand new CPS, brand new shielded wires going to the ecu) I will run a stimulator test to see if this is a megasquirt issue.
Once these are figured out, I'll try to start. If no start, I'll test for spark.
Questions:
-Any input on possibilities?
-Should fuel pressure be held after system prime?
-Is my FPR bad?
EDIT:
Pinched the fuel return line and ran the pump, pressure shot up above 3 bar like expected, then once the fuel pump shut off, the pressure still went to 0. I think the FPR is fine and there just isn't a check valve on the new fuel pump? Intuitively this makes sense to me, all the pressure just goes back into the tank backwards through the pump.Last edited by saturnv7890; 07-07-2013, 05:27 PM.Comment
