eta o2 sensor - stupid question..
  • LateFan
    • May 2013
    • 4438
    Pretty basic question here...
    On an eta motor with automatic, is there a trick to getting to the oxygen sensor? I've got the (flat) tool over the wires and on the nut, but there's no way to get a ratchet or extension anywhere near the 3/8 hole. Very tight to the trans case. No way could you use a tall o2 socket from above I don't think.
    Do you pull the exhaust mounts and stretch the exhaust down & away? Will I torque the exhaust manifold connections by doing that?
    Thanks -
  • SmokeE30
    • 1730
    Try using a open ended wrench that's what I usually use If they arnt that rusty
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • e30trooper
      • 11576
      This or vice grips. Make sure the plug is disconnected so it can turn without being twisted. Should only be a 2min job.
      • LateFan
        • May 2013
        • 4438
        Well, good. It looks so simple but I just couldn't get at it.
        Thanks!
        • LateFan
          • May 2013
          • 4438
          Yep, that was easy!
          7/8 or 22mm open end, from the trans pan side - pops right out.
          Thanks all -
