Another no start issue need help - no spark no fuel SOLVED
  • DoneRightBimmer
    • May 2012
    • 158
    My e30 1993 325i cabrio will not start. New spark plugs, fuel pump already. Car cranks but won't start. Fuel not priming when key is turned. If I jump fuel pump relay the fuel pump works but car still won't start. Stomp teste the codes and it came out 1222. Does It sound like DME or maybe the main relay I need help.
    SOLVED Crank Position Sensor was bad.
    The pump does not prime when the ignition is turned on. The pump only runs when the DME sees timing data from a rotating engine. Does the engine have spark, does the pump run when cranking? Those answers are clues to where to look for the problem.
    A 1222 is a Lambda fault, which can be the result of a bad O2 sensor but is more commonly from intake leaks. A smoke test will find any leaks and the O2 sensor should be replaced as scheduled maintenance every 100k miles.
    • Bmwb
      • Jan 2013
      • 196
      having the same problem , starts when it feels like it tho Im getting spark and all replaced pump , injectors and waiting on a few parts to come in , replaced the cps as well
      Sold Black BMW E30 325IS
      1987 bmw e30 euro part out
      1990 Bmw 325i Cabrio 2.9
      Metric Mechanic 2.9 stroker
      Holset Hx35w CXRacing Manifold
      MegaSquirt ARP HeadStuds
      OEM HG AEM Methanol injection
      20psi
      • DoneRightBimmer
        • May 2012
        • 158
        pump doesn't run when cranking. pump will only run when i jump the 30 and 87 on the relay but the engine wont start even if i do this and its getting fuel. Car was running then left for a few days now wont start. im gonna check spark tomorrow. all intake pieces were checked. would O2 sensor prevent start up?
          The pump not running when cranking could be:
          A bad fuel pump relay or a problem in the engine harness
          No timing data to the DME
          No power/ground for the DME
          A bad DME
          Is there spark when cranking? That would help narrow the search area.
          • DoneRightBimmer
            • May 2012
            • 158
            So I checked spark and not getting anything on that end. So no spark and no fuel when cranked.
            I ordered new main relay, fuel pump relay, and Crank position sensor as well as O2 sensor seeing how the car is at 100k and I don't think its ever been changed. After these part are installed ill know that the sparkplugs, fuel pump, relays, fuses, CPS are all new. FYI the water pump, acc belts, and timing belt are also new even thought these are probably irrelevant to the no start issue.
            So if It still doesnt start after all this does that leave the DME or bad wiring as the causes? Thanks
            • DoneRightBimmer
              • May 2012
              • 158
              Turned out to be my CPS installed a new one and the car started right up.
