Kachow! Offset-dish forged pistons
  • SkiFree
    • Jun 2011
    • 2766
    So after a couple weeks worth of fiddling around I'm happy to say that the new design is finished.
    Started with a mold of the 885 chamber ....
    popped out ....
    Little solid works love ....
    and wah-la these little babies pop out! (these are speced for my stroker build running the 2.9L kit running 84mm crank and 9.75:1 compression)
    ADAMS Autosport
  • jaywood
    • Jul 2010
    • 4528
    Oooooh, looks very nice. What material did you use for the mold?
    • digger
      • Nov 2005
      • 6122
      Looks good :)
      85 or 86mm bore?
      • LJ851
        • 7919
        Kachow indeed!
        Nice work Andrew.
        Lorin
        The M30 is God's engine.
        • SkiFree
          • Jun 2011
          • 2766
          Jaywood -- The mold was made from 80a urethane. Would have liked to use epoxy but the stuff is getting difficult to get in small quantities. As it turned out the sensors picked up everything fine.
          Digger -- Went conservative; 85mm bore.
          Lorin -- Thanks, just one step closer.
          The other upside to these is we'll be able to use them for the stroker kits and custom piston orders without bumping the price up.
          ADAMS Autosport
          • digger
            • Nov 2005
            • 6122
            Any reason for not simply mapping the 8.8 or 9.7:1 piston?
            • CarsSuck
              • Oct 2005
              • 968
              any chance in getting these for an 89.6mm crank? They're almost as common as 2.8 cranks.
              --Will
                • 37829
                Wow Andrew, nice!
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • AlphaE
                  • Sep 2011
                  • 503
                  some jerks have ALL the cool toys:) :) super jealous! especailly of the fact that you have the means to do that kinda work. VERY COOL!!
                  Now with 2.7i power!!!
                  • SkiFree
                    • Jun 2011
                    • 2766
                    Yes, depending on a couple factors.
                    The three things to balance is the pin height, ring package, and the meat available above the top oil ring (along with valve reliefs). In a nut shell with a 89.6mm w/135mm rods you're crunching all these things closer together (as with any stroker piston).
                    digger - A stock short skirt 8.8 piston was used in conjunction with the mold.
                    Matt and AlphaE - Thanks guys.
                    ADAMS Autosport
                    • Cabriolet
                      • 9620
                      dang Andrew! if i didnt now have a s14 i would be placing an order right now.
                      Much wow
                      I hate 4 doors
                      • SkiFree
                        • Jun 2011
                        • 2766
                        Eric, having an S14 around is not to be wasted! Lets get you an 02 to go with it.
                        ADAMS Autosport
                        • deutschman
                          • May 2008
                          • 5958
                          Oh cool. Id like to use these in my next m20.
                          • digger
                            • Nov 2005
                            • 6122
                            should be able to get it to work
                            stock stack height is 37.5 mm crank throw +135 mm rod +34.2 mm piston comp height = 206.7 mm (deck height is 206.2mm so sits 0.5mm above deck)
                            with 44.8 mm throw you need a 26.9 mm compression height instead of stock 34.2 mm.
                            MM do this with a 138mm rod on their 86mm bore rally motors so the piston comp height is even lower again!. The bigger the piston the farther the valve relief is away from the edge and and ring grooves (with stock valves)
                            you can use smaller wrist pins, thinner rings and the pin into the oil ring.
                            • Pocket Chant
                              • Mar 2012
                              • 403
                              Ugh. I want to build my M20 so badly. After I get new front tires I'm going to start collecting parts.
                              Oh, and it's Voila ;)
                              1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
                              MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
                              Originally posted by MclubSport
                              Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
                              Horrible with responding to PMs, I'm so sorry.
