Specs on the stock "i" cam?
  • klrskies
    • Oct 2004
    • 20
    Does anyone have specifications on the stock "i" cam?
  • Insanity
    • Jan 2006
    • 135
    I've been wondering that myself. It seems pretty well designed though from what I've seen with stock dynos..
    • klrskies
      • Oct 2004
      • 20
      Yeah, I'd like to see how it compares to what's being used from the aftemarket. I'd like to plug it, and other aftermarket cam specs into my Desktop dyno software too....
      • Insanity
        • Jan 2006
        • 135
        I wouldn't trust software like that. Most of the stuff of that sort that I've used seems to be about as accurate as a random guess of how the performance will increase. I remember trying to get the thing to show a high-end power increase by having a really late intake closing and a plenum/intake manifold that would only be good at the high end, and the results didn't make any sense at all. I think my power band shifted towards the mid range or something according to the program.
          • 34847
          I think it has 252* duration and 10mm of lift.. but I'm not positive (I've seen many conflicting figures).
          • Insanity
            • Jan 2006
            • 135
            Well, even if the 252 spec is correct, 252 is pretty ambiguous when it comes to cams. Considering there's "advertised" duration (which pretty much means nothing), "seat" duration, which most OEM manufacturers use, and @.050" duration, which is a baseline due to the ambiguity of the other two, but you'll rarely find specs from manufacturers given in .050".
            For example, a certain nissan engine I worked with has a "248" degree camshaft, but it's seat duration, and all the aftermarket cams are rated in advertised duration. When someone measured the aftermarket cams using seat duration, they found that the aftermarket cams which were advertised as 276* were actually only about 254* using the Nissan OEM method, which accounted for their very paltry gains.
            • xLibelle
              • Aug 2004
              • 2673
              b27 = 236 code B
              b25 = 260 code K
              • Scott314
                • Jan 2005
                • 287
                I've heard 256. But I've heard so many conflicting variations, that it pretty much carries no weight.
                My fast says: traction control is for the faint of heart :evil:
                • xLibelle
                  • Aug 2004
                  • 2673
                  Did i stutter?!
                  260 came out of my shop manual... i'll go check the lift now... 6.5mm on a slightly worn cam
                  • Mitch M
                    • 881
                    Re:
                    Here's what I measured on a used but nice stock "i" "K" grind. Measured @ the same lifts and as the Cat Cam web site.
                    0.010" lash, lift @ valve
                    0.10 mm 266 deg
                    1.0 mm 217 deg
                    Lift @ valve 10.08 mm
                    American spec comparison
                    212 deg @ 0.050"
                    Same basic spec intake and exhaust.
                    • xLibelle
                      • Aug 2004
                      • 2673
                      scratch the word slightly
                      • klrskies
                        • Oct 2004
                        • 20
                        Mitch M,
                        Did you record any lift values? Thanks for the info!
                        • Low Level E30
                          • 1646
                          0.10 mm 266 deg
                          1.0 mm 217 deg
                          212 deg @ 0.050"
                          Can you explain these numbers to those of us that don't speak "Camshaft" ? :D
                          Is there a difference between the US-spec and Euro-spec camshafts, for 325i's?
                          • StereoInstaller1
                            GAS
                            • 22679
                            He means metric to english...basically.
                            Insanity, how much have you messed with Desktop Dyno? IMO, using the SBC's that I have been beating on for years and years, that shit is always just about perfect. Lookig at the database, I see just about nothing euro...hard to believe all the techies there are and none uses DTD.
                            Good to see someone working on this.
                            Luke
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • Insanity
                              • Jan 2006
                              • 135
                              I haven't used desktop dyno. I tried engine analyzer pro and some other one. I'll see if desktop dyno is any better. Do they have a trial version?
