So I'm trying to remove the fan clutch in an 89 325ix, in order to change the water pump and timing belt, and it will NOT budge. I've got the 32mm wrench, and have been using a screwdriver to hold the rotating assembly still, but no luck. I even bent a couple of screwdrivers! I bought a rubber malet specifically to smack the wrench, but it made no difference. This thing is STUCK! I sprayed some PB blaster on it, and I'm going to try again tommorow morning, but I dont have high hopes, as I just spent the last 3 hours smacking the thing (not even exaggerating).
What I would like to know about are my other options. Is there a way to pull the water pump without detaching the fan? Do I have to figure out a way to cut through the shaft the fan is attached to? Is te shaft part of the water pump, or a separate part? Is there some trick I'm missing?
I do know that the fan clutch is reverse threaded, so if I'm looking at it from the front of the car, I need to spin it clockwise.
please rescue me from fan clutch removal hell!:firehop:
Problem solved, I pulled the water pump with fan attached, and picked up a new fan clutch + water pump pulley at the scrapyard. Thanks everybody!
