Hesitation in the higher RPMS
  • mod_junkie
    • Jul 2012
    • 285
    So when I'm stomping on it going through gears my 90 325i is hesitating in the higher rpms almost like its cutting out or slipping maybe? I dont know whats causing it. Any ideas? Hoping someone can point me in the right direction thanks in advance.
    Originally posted by Rocla
    And yes, you must remove complete assembly from the car, unless you are a gynegologist
  • DesertBMW
    • Aug 2011
    • 1030
    Tired valve springs floating, common for high mileage M20. Mine does it too, that's why I will get rid of the M20 soon.
      That is not a common M20 problem, though worn valves & guides are a common problem on any high mileage engine.
      More likely causes are a bad WOT switch in the TPS, aged ignition wires, distributor rotor/cap, the wrong plugs (use NGK ZGR5A), fuel supply issues (clogged filter, weak pump, bad FPR, clogged injectors), and/or a partially clogged catalytic converter.
      • mod_junkie
        • Jul 2012
        • 285
        Thank you for the reply I guess I'll be going along that list lol
        • mod_junkie
          • Jul 2012
          • 285
          bump
          • ak-
            • 12422
            Had this problem on an eta.
            Distributor cap contact points were a little corroded so I sanded them down a little and 80% of the hesitation went away; temporary fix.
            1991 325iS turbo
            • bddog
              • 351
              My car is chipped. When I add Lucas to the fuel, it stops the hesitation. I buy it by the gallon from Amazon.
              • mod_junkie
                • Jul 2012
                • 285
                bump
                • efficient
                  • Feb 2012
                  • 3312
                  bad afm?
                  • mod_junkie
                    • Jul 2012
                    • 285
                    well I was hoping someone would have maybe had this experience and could of narrowed it down to a couple different options but it looks like I will be chasing it down by replacing parts LOL
                    • Gregs///M
                      • Mar 2012
                      • 2459
                      Could be bad AFM.
                      Owner - Bavarian Restoration
                      BMW and European Electronics Repair and Restoration
                      www.BavRest.com
                      My Feedback Thread
                      Our Facebook!
                      Follow our Instagram!
                      • codrum
                        • Jan 2011
                        • 279
                        If you haven't changed your plugs and gapped them correctly I would start there. It's quick and cheap and will rule out one of the potential issues. I had similar breakup problems in the high end (although I'm FI), gapping my plugs correctly fixed the issue.
                        If you can remove the chip or put a stock ECU in and see if the hesitation goes away.
