what would a 4.10 do to my M20?
  • digger
    • Nov 2005
    • 6198
    #46
    Originally posted by SmokeE30
    Tire Size also needs to be taken into consideration, you could run a 4:10 with a taller tire and have your cruising rpm the same as a 3.73 running a shorter tire.
    what would be the point of that though? and you would have difficulty changing the the wheel radius 10% (more than 2.5" bigger diameter) without creating other problems. usually when people use non standard size tyres its a few% difference in rolling radius.
