m20 problems.. help
  • Tismael711
    • 791
    m20 problems.. help
    hey r3v, heres the story of my m20 problems... hopefully you guys can help:
    ok so after a small engine fire and blown head gasket.. i replaced my old m20 with a 104k m20 (with matching miles cluster) and had it refreshed. by refreshed i mean the head was shaved by a machine shop to insure that it was within spec, all new gaskets, seals, hoses, wire harness, o2 sensor, thermostat, water pump, timing belt, etc etc etc... pretty much everything.
    the car was back on the road may 2013 and was running well. topped it off with oil as needed and got an oil change july 2013 @ 105k miles. up until recently the car was fine besides needing a new exhaust system and a valve adjustment.. both of which i was planning on doing very soon.
    just recently it started to blow smoke under acceleration.. and now it constantly hesitates and feels weak under acceleration. overall sounds and runs like shit.
    it also was leaking gas last week... but that was easily fixed by readjusting one of the hoses that run to the fuel rail and tightening the hose clamp. im just under 107k so its only been 3k miles since the refreshed motor. what do you guys think..?
  • EatsHondas
    • Sep 2012
    • 404
    What color smoke? Black is too much fuel, blue is burning oil, and white is coolant. All three suck.
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
    • Tismael711
      • 791
      It's blue. What could be the cause of burning oil... Esspecailly after all the recent maintenance?
      • Poorboyz
        • May 2012
        • 2117
        Bad rings or blown head gasket. Those are only way oil can get into the combustion chamber.
        Check your coolant reservoir for oil floating in there. Check the oil dipstick for a milky substance.
        You claim loss of power and it seems like it happend pretty fast so I'm gonna go with blown head gasket.
        Sent from my Galaxy Nexus using Tapatalk 4
        Rebuilding since 07/06/2016
        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
        Poorboyz Feedback Thread
        • andrewm
          • 456
          Get a compression check done - sounds like a blown HG.
          1987 Delphin 325e Sedan - Natalie
          1990 325i 24v
          1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
          • Sirotto
            • 317
            You mentioned the head was skimmed, did they do a valve job? They should have removed the valves to do the work anyways, if they stuck the valves back through the old oil seals then that would be your issue. What brand of HG did you use, how much was skimmed off the head. Need a little more info before we jump to a cause.
            "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
            "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
            • 603Racing
              • Dec 2010
              • 612
              You can also check the outside of the block for fresh oil. Often times the gasket will leak/blow between cylinders 3 and 4 on the exhaust side of the block. If you see fresh oil just below the exhaust manifold but not above it, then it's coming from the gasket.
              90 325i DD/Track
              03 Durango 5.9
              Originally posted by e30mpg
              It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
              • Cabriolet
                • 9620
                did you use victor reinz for your get and bolts? did you hone the block before putting in the new rings?
                does the car sound like a WRX sti?
                if any of the above, you need to do another HG.
                Much wow
                I hate 4 doors
