Injectors not pulsing...no start
  • SpeedWiz
    • Jul 2009
    • 31
    So I recently bought a 325es that had been converted to I components,
    The engine will currently not start because the injectors will not pulse therefore no fuel in the cylinder
    I have spark
    Car fires with starter fluid
    Checked the CPS good reading
    Fuel in the fuel rail with good pressure
    power at the injectors
    No oxygen sensor hooked up (shouldnt matter)
    Temp Sensor good
    Any Ideas?
  • TobyB
    • 5298
    No connection between ECU and injectors?
    Blown ecu?
    If you've got power to the injectors AND the ECU will run the ignition,
    (since it will run on starter fluid)
    there's not a lot else it can be...
    hth
    t
    • 603Racing
      • Dec 2010
      • 612
      By I components, you mean head, intake, harness, etc.?
      Did you do a noid light test?
      90 325i DD/Track
      03 Durango 5.9
      Originally posted by e30mpg
      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
      • SpeedWiz
        • Jul 2009
        • 31
        I have four ecu that I have been switching out..
        And I just changed the wire harness and same problem..
        Gonna change injectors today
        • SpeedWiz
          • Jul 2009
          • 31
          Will do a Noid test today too
            With what you have checked and what you tried it sounds to me like you may have a harness problem. Ohm out the injector control circuit wires.
            • SmokeE30
              • 1730
              I would suspect the c191 injector harness plug under the intake manifold but like others have said a noid light on the injectors would be the easiest way to tell if they are firing
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
