continued l-jet M20B23 troubles
  • kronus
    • Apr 2008
    • 13032
    roger, will try. pinging as in detonation, right?
    cars beep boop
    • LJ851
      • 7919
      Correct.
      I just did some research and saw some #s like you are talking about. Is your dist on this list ?
      The only reason i could imagine such a low advance # would be for emissions, not for performance at all.
      Lorin
      The M30 is God's engine.
      • kronus
        • Apr 2008
        • 13032
        I will approach it with the carbed-M10 approach to distributor tuning, i.e. advancing the piss out of it. However, if I'm advancing until the detonation point with just mech advance, wouldn't that put it solidly past that point with vacuum hooked back up?
        cars beep boop
        • LJ851
          • 7919
          I was just thinking of a way to see if you can find your missing horsepower at full throttle. Yeah, it could still detonate at part throttle with vacuum hooked up and another potential drawback could be that you are moving the entire timing curve up so you are changing the timing at idle as well.
          It might not be an issue or you may need a dist that has a longer advance curve (or you could modify yours)
          Lorin
          • LJ851
            • 7919
            Any news?
            Lorin
            • kronus
              • Apr 2008
              • 13032
              yup! there is success!
              Retimed it yesterday. Ended up giving it a lot more advance than it had, and now it's great, chirps 225s, accelerates up hills, etc. It's still not fast, but it's good now. Still runs hot, though, so I think either I have an air bubble, the radiator is done, or an HG leak pressurizing the coolant. The temp gauge and/or sender might also be going - it will be steady midway between middle and the mark to the right of it, and then randomly rise up to the mark and come back down without much of a change of engine load.
              cars beep boop
              • LJ851
                • 7919
                I thought so. :up:
                Lorin
