continued l-jet M20B23 troubles
  • kronus
    • Apr 2008
    • 13032
    (continuing from http://www.r3vlimited.com/board/showthread.php?t=291366)
    situation: very low power being produced by my l-jet M20B23; runs hot and overheats at high load.
    diagnostics:
    compression is good (~170ish all around)
    timing belt is on right
    timing is set to 19 degree mechanical advance at 3K rpm with vac advance disabled
    mechanical advance works
    vacuum advance works
    plugs are new
    injectors are freshly rebuilt
    fuel pressure is in spec (2.5bar)
    smoke tested extensively, no vacuum leaks
    no obvious signs of oil and water mixing
    any ideas on things I should check at this point? It feels like it's producing about 60 horsepower..
    cars beep boop
  • Silverdogz
    • Aug 2012
    • 168
    ECU corrosion?
    so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
    • LJ851
      • 7919
      What is the total mech advance ?
      Lorin
      The M30 is God's engine.
      • kronus
        • Apr 2008
        • 13032
        19 degrees, there was a convenient mark on the harmonic dampener for it already.
        cars beep boop
        • LJ851
          • 7919
          That cannot be enough advance. Even air cooled engines run way more than that. Rev it up to 5k and see if it keeps advancing. That thing needs at least 30 degrees total mechanical advance.
          Lorin
          • accident
            • 7303
            Convert to fuel injected and electronic timing. Problem solved.
            Moral of this story?
            • kronus
              • Apr 2008
              • 13032
              I'll play with it, but the 19 degree spec was confirmed by a few different sources, and there's a very obvious mark on the damper..
              it's already fuel injected. converting to air injection soon.
              cars beep boop
              • accident
                • 7303
                Jetronic is not fuel injected, it's caca.
                • LJ851
                  • 7919
                  I wouldn't doubt that mark is how BMW checks it, i'm just saying it needs to go higher and it would be worthwhile checking total mechanical adv.
                  Lorin
                  • kronus
                    • Apr 2008
                    • 13032
                    you keep saying total mechanical.. do you mean total of vacuum + mechanical?
                    cars beep boop
                    • ak-
                      • 12422
                      i like air injection
                      1991 325iS turbo
                      • accident
                        • 7303
                        du.
                        • LJ851
                          • 7919
                          No, just the advance provided by the centrifugal weights inside the dist with no vacuum assist. Assuming the vacuum pot advances, vacuum would add additional timing on top.
                          Typical total centrifugal advance is high 20s to mid 30s. Vacuum advance will add 10 or 15 degrees on top of that for a total of high 30s to high 40s at part throttle (high vacuum)
                          Total centrifugal advance could be all in by 3k or might not be all in until much higher like 5k+.
                          Since i used most of the internals of an e21 323 dist when i built my 911 dist i am fairly intimate with them. The advance springs are very light and i would be surprised if you got much more advance past 3k.
                          Lorin
                          • kronus
                            • Apr 2008
                            • 13032
                            I see. It was pretty consistent above 3k after I set it.. maybe 5 more degrees?
                            cars beep boop
                            • LJ851
                              • 7919
                              I would leave the vacuum advance off and keep advancing it until the engine pings and then back off 5 degrees or so.
                              Turn it up 10 to 29 degrees and see what happens.
                              Lorin
