Okay so I bought a 1990 325is with a snapped timing belt and this is what I did....
1. Replaced Timing belt - No start
4. Removed Valve cover to find a broken rocker.
3. Removed head and took it to a head shop and all the the exhaust valves were bent and 1 intake was bent
4. Got that all replaced and bought a new rocker and head gasket set and put it together.
5. Car starts right up wont idle once warm so I adjusted the AFM.
6. Idles now but its really rough(engine seems smooth at higher RMPS)
7. Unplugged the sparkplug wires one at a time while the engine was running which seemed to have no effect on it for cylinders 4, 5, and 6. (even with all at the same time)
Cylinder 5 seems to be the only one that changes nothing no matter what and yes it has spark.
Also I get a check engine with at idle most of the time. CEL 1215 I believe.
Next step I was going to try was compression test then check the injector.....
All advice is appreciated.
