Another m20 rough idle problem--i know i know..plz read
  • Mthrizzle
    • Oct 2007
    • 390
    BORED HERE AT WORK SO I THOUGHT I'D "ASK" YOU GUYS FOR SOME HELP SINCE I HAVE EXHAUSTED EVERY SINGLE OPTION EXCEPT FOR 2..
    I RECENTLY DID A 327 SWAP, I.E 2.7 BOTTOM END WITH 2,5 HEAD INTAKE ETC..BLAH BLAH BLAH..
    WHAT WAS DONE TO ENGINE - ( SUPER ETA)
    1. I HEAD, INTAKE, 272 REGRIND CAM, HEAD GASKET TIMING BELT WATER PUMP ETC.
    2. MILLER MAF AND CHIP WITH MUSTANG INJECTORS
    THE CAR STARTS AND RUNS BUT HAS A VERY ROUGH IDLE WHEN WARM AS THE TEMP GETS HOTTER THE ROUGH IDLE INCREASES.
    CHECKED FOR COMPRESSION - GOOD
    CHECKED FOR SPARK - GOOD
    CHECK FOR FUEL PRESSURE -GOOD
    CHECKED ECU ( 3 DIFFERENT ONES ) SAME ISSUE
    I HAVE ISOLATED THE ISSUE TO A DEAD CYLINDER ON # 5
    WHAT I HAVE LEFT TO DO IS
    1. CHECK VALVE CLEARANCE
    2. LEAK DOWN TEST
    MY QUESTION IS THIS..WHAT COULD POSSIBLY CAUSE THIS ? I HAVE
    GOOD COMPRESSION, FUEL PRESSURE, SPARK, AIR -
    NO SMOKE FROM TAIL PIPE , NO VALVE TRAIN NOISES
    JUST A DEAD SPARK PLUG -
  • dnguyen1963
    • Nov 2011
    • 2649
    I assumed that you have put in a new spark plug and the symptom persists. Have you check the spark plug wire? If your wire is okay then I would look at the distributor and cap.
    • Mthrizzle
      • Oct 2007
      • 390
      YES I HAVE, WIRES, PLUGS, CAP AND ROTOR BUTTON :up:
      • I got it, yes!!
        • Feb 2007
        • 206
        Have you actually checked to see if the injectors working? I had a bad wire(pulled out)on my injector plug and it wasnt working. Something to check if you havent.
        • Mthrizzle
          • Oct 2007
          • 390
          removed injector rail and powered up rail out of car..all injectors working
          • Mthrizzle
            • Oct 2007
            • 390
            Will be checking valves train tomottow ..will update
            • Mthrizzle
              • Oct 2007
              • 390
              heads got to come off- suspect valves
