Yes another one.... But with video
How can you be sure that there is no intake leak? If you have not done a smoke test then you cannot be sure. 90% of idle issues can be traced to intake leaks. -
Mostly because i'm confident that when I changed all of the intake manifold and related gaskets and rings, I did it correctly. Also I checked using carb cleaner on many areas that were suspect, and after a touch of blue rtv on the three metal angles that connect to the intake manifold carb cleaner didnt effect the idle at all. Yet no noticeable improvement.
Any suggestions?Comment
Since we're all really good at not answering what solves our problems on these forums let me say for future reference if you having the trouble I had in the video, get a new ICV. That is all. (as long as you dont have a vacuum leak.)
Told you it wasn't a vacuum leak.Comment
Did you try a different AFM?Comment
You're right valves totally need adjusting. Haven't quite gotten around to it yet.
In my last post I explained the drop in idle and almost stalling was due to a bad ICV, everything else is fine. I both cleaned and re-lubricated the old ICV to no avail, so I got a used one, and immediately the problem was solved.Comment
